Question about Sony Playstation 3 (PS3) Console
PS 3 power up problem - 3 quick beeps with red blinking LED...
Hey Folks -
I seem to have the ubiquitous and seemingly generic PS3 power up problem. When I press the I/O button, the unit fan comes on and all seem "well". After 1-2 seconds, the unit beeps quickly 3 times and then red LED flashes. If I press the I/O button again, the LED goes solid RED. If I press again, the same power issue.
Is there a way to focus on the exact problem (HD, RAM, CPU, G-CPU, cables, etc.)?
There seems to be any solutions to this issue (bad heat transfer goop on the G-CPU, power supplies, etc.).
* If I open the unit to look inside for obvious issues, will Sony still fix the unit if I have to send it to them (for $150)?
* I bought this used on Ebay...thus I'm sure my warranty is non-existent. Right?
Thanks,
Mike
  • Anonymous Mar 10, 2009
    Its called the YLOD, yellow light of death. It seems to be a fault that Sony will not own up to caused by either
    1. Hardware malfunction on the motherboard due to heating/cooling (solder physically cracking/breaking) which can be fixed by "reflowing", which is a fancy way of using a machine that has a super controlled (+ or - .5 degrees) hot air nozzle to re-melt the solder on the base of the defective chip to re-attach it.
    2. The power supply has the failure in one of its capacitors or diodes.
Not a solution as such, but I have had the same issue, replaced HDD with aftermarket and original PS3 drives, replaced PSU with replacement original and Hong Kong variants, tried different Blue Ray drive in there added new Silver based Thermal paste to CPU cores, double checked the Fan in a second PS3, even tried with and without a card reader (last ditch attempt). All failed to fix the red led issue, and all the components are tested working, the only thing left is the main board, which has to be the only component left at fault.
My console was a gen 1 , and was well passed warranty, if yours is also out of warranty, successful repairs are Hard Drives and Power Supplies, I have seen console come back with these fixes. If you can fix it with either of these, good for you, these are reasonable costing components that are worth a try, and are sell-able if not successful. After this point, its not worth throwing anymore money at it.
Part it up and sell it, buy another console...I did
Posted on Mar 10, 2009
    Problem Solver:
  • 5 Answers
I would try to buy a inner cooler
Posted on Mar 24, 2008
    Genius:
  • 1,019 Answers
Hi Mike,
If you open the unit, you can forget any chance of a warranty return.
Heres what i,d Do:- find a friend thats just recently bought a PS3.
Ask for his Warranty Card, return the Unit to Sony or the repair centre. your dealing with serious issues here mike.
these are too new, to go playing lets open the case up.
Unless your a real PCB electronics specialist ( which i,m certainly Not ) don,t waste your time.
3 beeps-red lights could be Overheating, hard disk errors, Bios fault if they have 1.
Mike @ Compurepair.
Posted on Feb 24, 2008
I have the same problem that you are talking about. It happens when i try to turn it on or eject. I believe its a disc jam or something similar. I shot sony customer service an email and am waiting for a response. It seems that is mostly happening with the 60 gig systems.
Posted on Jul 05, 2008
If it wont come on without the hard drive then the CPU is probably fried. no fix for fried CPU
Posted on Jun 28, 2008
Have you found a good solution for this problem? I'm having the same issue as you.
Posted on May 18, 2008
When I turn on my PS3 will not load the basic applications, neither the games. When I press the PsS button on the cotroller to turn it off I will get the option but it will not tunr off and i will get a...
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button AGAIN, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
*****CHOOSE RESTORE FILE SYSTEM WHICH IS OPTION 3****
and DONE!!
www.1RepairStop.com
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped showin the icons but its loading up the front screen is there but no icons ?
Your software needs re-installing, follow this procedure :
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and switch off back into standby mode (red light on)
Step 3. Press and hold the power button again. It will beep when you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. A menu will load up with 6 options. Choose option 3 first "Restore File System" and go through this process. If this does not work do the above but choose option 4, then as a last resort option 5. A warning though, option 5 will erase all your data on the hard drive.
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
Hey, i had my ps3 on hdm1 and i went to swtich it back.. it said i had 30 seconds left and i pulled the plug. now neither hd or regular wont work. i plug them in and the screens blank. nothing comes up to...
Try a video reset:
While the PS3 is off (solid red led), Hold Down the power Button until you hear the SECOND BEEP, quickly release.
Let me know if that solves it.
Nov 12, 2010 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
How do you format a ps3
Ok, follow these simple steps :
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep once when you press it, once more 5 seconds later and then once more and it will turn back off onto standby. Release the power button.
Step 3. Press and hold the power button again. It will beep once when you press it, beep again 5 seconds later then it will beep twice quickly. When you hear these 2 quick beeps let go of the power button.
Step 4. Your PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then go on to step 5.
Step 5. A menu will load up. Select option 5 "Restore PS3 System". This will format the PS3 and reset all settings back to default.
Aug 27, 2010 | Video Game Consoles & Games
Corrupt hard disk
Put your PS3 in Standby Mode.
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
-REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step.
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My PS3 plays blue ray movies,dvds,ps2 and ps 1 and no ps3 games
hold the power button down when it is red till you hear the quick beeps then select the file restore this is a diagnostics menu..remember you have to hold the power button down till you see a menu that youve probably never seen
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 not powering up but has blinking red light.
Tell Sony !! I did now im gettin a new 80 gig (lost all my online data tho!)
but hey im gettin a new unit plus there sending me cod 5 cos thats stuck in the ps3
sont no about this fault an its not fixable (smoked mother board!!!)
hope this helps..
ps
mine was outa warranty.(60 gig)
Nov 17, 2008 | Sony Playstation 3 (PS3) Console
PS 3 Won't turn on blinking light
Are you trying to turn the PS3 on via bluetooth controller? If so, attempted to turn PS3 on from console itself. Sometimes the controller will get out of sync with the system and not allow for turning on remotely.
Sep 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
4,682 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
