Question about Kitchen Ranges
My ken more stove
My kenmore electric stove has no power. after plugging it in it turned on, but now has no power
  • 1 more comment
  • Stephani Feb 16, 2008
    where would I find the model
  • thervs Sep 26, 2008
    I have a Maytag electric flattop stove. When i had 3 burners on and oven on it shut off. Now has no power. Have reset ciruit breaker, still no power.
  • Hjalmer Lamminen
    Hjalmer Lamminen May 11, 2010
    I will need the make and model number to assist you.
    If you have a display, but it does not heat, you may have to reset the circit breaker at your electric panel or replace one of the two fuses that feeds it.
    You may only be getting one half of the 240v it needs to operate.
    President:
  • 1,314 Answers
Open the bottom drawer and look on the range
Posted on Feb 16, 2008
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Safely remove knobs from 50's Kenmore gas stove
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
Jan 07, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Won't work
It sounds like the receptacle you plugged the stove into does not have any power coming to it. Check in your electrical panel to see if the breaker needs to be reset, or if the fuse needs to be replaced.
Apr 18, 2009 | Kenmore 99123 Electric Kitchen Range
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 95413 appears to have no power
test the incoming power, insure there is a good neutral. (120/240v plug). if the supply power is correct, the unit will need to be checked for a open neutral.
Feb 20, 2009 | Kenmore 95420 / 95421 / 95422 / 95424 /...
Gas stove stopped working
Hi . I would begin by pulling the stove out and making sure it is plugged in. If it is, unplug it and plug something else into the plug like a blow dryer to make sure you have power to that outlet. If there is no power, you have either blown a fuse or kicked a circuit breaker. Go to your electrical panel to replace the fuse or reset the circuit breaker. good luck.
Feb 01, 2009 | Kenmore Kitchen Ranges
Small electric kenmore oven
sounds like youve shaken or loosened one of the power leads into the oven, check the circuit breakers first, make sure they have not tripped, if not turn off hte breaker and remove the back panel of the stove youre only getting half power to the unit doesnt sound like anything magor at all
Apr 29, 2008 | Ovens
Ge jbp77 radiant range
my stove shut off. it want stay on
Ken
Dec 11, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
102 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
