Question about Microtek ScanMaker 6100 Pro Flatbed Scanner
Colour Problem The scanner is giving everthing scanned a pale blue background, even a text document on white paper! I have tried reloading drivers and adjusting the colour settings but no good. Someone told me it might be the bulb wearing out. If so can these be replaced as I dont like to discard equipment if its repairable.
  • Anonymous Mar 12, 2008
    same problem. And this is on a brand-new Microtek 9800XL scanner. What a piece of ****. My other scanners never did this. I've tried everything from uninstalling drivers and reloading the most recent from their website with no solution to this problem. Tech support sucks too. I scan color text on a white background and I get a light blue or off-white background. Any help would be appreciated.
Sorry, that won't help. I've tried doing all that you state. And this is on a brand-new Microtek 9800 scanner. Wish I could help
Posted on Mar 12, 2008
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
    You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
    First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
    Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
    If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
    Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
    CanoScan Scanner can not complete a scan
    Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
    Jan 09, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
    After preview with correct colour, print comes up pale colours.
    Have you confirmed that the scan you are trying to print is good?
    Dec 13, 2008 | Canon CanoScan N640P Flatbed Scanner
    When scanning color document, blue tone is present as background shade
    Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
    Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
    DR-9080C BackgrounfColour Dropping Out
    Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
    CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
    Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
    How do I scan colored paper and still read print? HP Scanjet 8270
    First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
    Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
    When printing a scanned object, paper is all gray
    Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
    May 05, 2007 | Umax Astra 610P Flatbed Scanner
    Microtek ScanMaker 6100 Pro Flatbed Scanner Logo
    137 people viewed this question
    Top Microtek Office Equipment & Supplies Experts
    Alun Cox
    Michael
    Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
