Question about Hotpoint WMA64 Front Load Washer
Bearing gone Hi can you tell me how to get the bearing off the drum can't get the shaft to move ( do i pull the shaft out or push the shaft out) Thanks Andy
  • 1 more comment
  • windy10 Feb 16, 2008
    sorry it's a hotpoint ultima WMA64
    Thanks
    Andy
  • Gary Davd
    Gary Davd May 11, 2010
    Sorry this is a UK model not USA dont have any info on it
  • Gary Davd
    PLZ Post you complete model # from the machine
    Genius:
  • 1,554 Answers
Remove the top and bottom panel,
remove the front digital panel
remove the front tub access panel
now you can pull the unit out
Posted on Feb 28, 2008
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
Model 8600 , drum makes loud noise, not a squeak
HI,
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Jul 26, 2008 | Maytag Dryers
Loud banging noise whilst drum is turning to dry
hi put you hand in drum at the top at the back get someone to lean on top of dryer see if you can push drum upwards if so you need to change rear bearing if you do there is a cover in centre of the back held by two screws you will see a pin going through the shaft pull it out take bearing out some have a skrew holding it in to put new one in take lid off so you can pull drum up to push new one in place put pin and cover back its quite easy hope this helps
Jul 31, 2013 | Hotpoint Dryers
Broken belt replacement
hi mick, on the back there is small cover in centre held by 2 skrews take it off you will see a retaining pin on bearing take it out makes it bit easyier take top offto get to front panel as you have to take front off make a note of were wires go on everything there is 4 skrews in door aperture to take out and 3 or 4 behind kick place if you carefull when its ready to come off you can justabout fold front over the side write were wires go to door catch incase you pull them off once you get to drum put belt round drum pull drum forward so shaft comes out bearing the belt is tight to get on motor shaft this helps a bitonce on shaft pull drum up to fit shaft dont put pin in till u have front onlot easyier with help if 1st time but not to bad check bearing pads while you have grey plastic drum carrier off the front hope this is sum help
Mar 20, 2013 | Hotpoint Dryers
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
How to replace bearing in a 1991 chevy 1500 4x4 rear axel at driveshaft?
To replace pinon bearing you need to pull wheels and the brake drums off next pull cover off the back of the rear end (make sure you have a drain pan under rear end) next turn dive shaft till you see a small bolt remove bolt pull center pin out push axle in pull c clips out pull axels out remove four bolts holding ring and spider gears remove gears assembly next remove drive shaft remove bolt from pinon push pinon in remove seal and bearing
Jun 27, 2011 | 1991 Chevrolet K1500
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Kenmore heavy duty
I can only assume by rollers you mean bearings were replaced. Unless your dad measured both the ID Fit of the bearing and the OD fit [ inside diameter and outside diameter of the shaft and housings] new bearings could be on the small side of their tolerance, [new bearings are made to be within a certain amount of "slop" if the new bearing was on the outside tolerance, and the shaft or housing was on the large side of the tolerance, the bearings are still allowing the drum to move, and thump.
OR if belt driven, the alignment of the belt is important, if one pulley is out, and the other in, one shaft will be pulling and the other pushing, again a thump.
Something in the bearing/pulley setup has not been discovered bad yet, it takes micrometers and some knowledge of bearing tolerances to resolve this kind of problem.
Think about it, what can thump in a dryer? The tumbler cage. It is most likely that the journal or housings are wore, second the motor may have a front or rear bearing/ housing the same thing, gone bad,
This machine is old enough I would expect to find a worn housing or shaft, either drum or motor,most likely drum, check the alignment of the belt also, but most likely the thump is not cost effective to repair, plus Dad's time which is invaluable.
Start searching the sale sheets, and reading consumer reports, time for a new energy easy dryer anyway.
Will
Sep 16, 2008 | Kenmore 63942 Dryer
Removing drum bearing on a LG wm0532hw???
Remove motor stator and push in the drum shaft as far as you can. Try to put a hook in between the shaft and the bearing and pull rotating in every direction and keep pulling outward.
Good luck
Jun 04, 2008 | LG Washing Machines
Hotpoint WMA64 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
