Power supply When my laptop is turn on or restarted i get a fault saying that i need to use a 130 power supply before starting but if i use the battery on start up and then put the power cord in the system will work and charge battery can u tell me what is going on Please and thank u
Eric, your battery is probably falty, prompting the circuit to report fault, until power from the main substitutes the battery. I would get it tested and replaced.
Posted on Feb 20, 2008
G4 powerbook is frozen and won't restart
pull battery, disconnect power supply, hit power button.
reconnect power supply and try without battery installed.
try same procedure again with battery installed
Now try holding down c key and powering up
try different power supply
Jan 25, 2014 | Apple MacBook Mac Notebook
When I turn my macbook pro laptop on all I see is an envelope with a question mark
The computer cant find a start up directory so your Harddrive may be corrupted or physically bad. But there are other causes so...
First thing to do is turn it off, remove any connected devices or cables, unplug the power supply and remove the battery. Wait a minute or two then replace the power supply leaving the battery out and start the macbook while holding down the SHIFT key on the keyboard to start in Safe mode. If that works you're lucky and you can restart the computer normally (no shift key) replace the battery and any connected devices one at a time (with a shut down in between) to see if one of your devices was to blame. If that didnt work you will need to start the computer from your OSX start up DVD to repair your start up directory/harddrive if possible. See this link http://support.apple.com/kb/TS2570 for more details. let me know if you need more help.
Oct 11, 2013 | Apple MacBook Pro Laptop Computer with...
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Windows will not start. Computer restarts while loading
good day sir/maam, there are several reasons why the windows restart.
  1. Power supply or charger problem. To solve this you may need to find another charger to use on your laptop.
  2. Battery problem. try a new battery.
  3. systemboard problem. sad to say this but you may need to bring it to your vendor for service
  4. poor Windows installation. you need to reinstall windows
  5. Memory. replace the memory module.
The most common culprit is number 1 and 2. if not try the rest. may this guide you.
Aug 04, 2009 | Dell Latitude D800 Notebook
Hi i have got a medion mim2230 laptop. when i turn it on i get a page that comes up and says 'sorry for the inconvienience, but windows did not start successfully. a recent hardware or software change...
hi
i have had the same fault with my medion mim2230 and tryed everything you list and i now have put it down to a battery pack fault why i say that is i removed my battery and laptop works ok some i ordered a battery of
ebay and placed it in my laptop and now its ok but just to make sure
i put my old battery pack back in my medion mim2230 and it come up with the same fault again so turned laptop off and replaced my laptop battery with my new one from ebay and its working ok
May 14, 2009 | Medion md40298 Notebook
Mac book will not turn on.
http://www.ifixit.com/Guide try this location for a guide
re-set your pmu 1. disconnect battery and power supply 2. hold down start button for 5-6 seconds 3. re-connect battery and power supply try to start if nothing might be your dc-in board/ has failed good luck
Mar 28, 2009 | Apple Computers & Internet
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Start up
If the Computer In question is a PC Desktop computer a few issues. First power supply may be malfunctioning. Second check the the CPU fan inside computer is running and not full of dust when you turn it on. If it's dusty, get vacuum cleaner and clean it. Fans need to be able to work without overheating because CPU runs hot.
Thirdly try to take out battery and restart computer. If starts up replace with new battery.
In Case it's a laptop. Take out battery and try to run using power supply and if turns on place battery back in. If battery isn't charging you will need a new battery. Let me know how you go!
Aug 03, 2008 | Computers & Internet
Computers & Internet Logo
147 people viewed this question
Alun Cox
David Payne
David Payne
