Question about Compaq Presario 1200 Notebook
Display problem hello, i accidentally changed my resolution from 800x600 to a higher one. when i try to change back, everything is big and blocky
  • 58 Answers
Try to do a system restore, for windows (xp or vista) click start>all programs> accessories>system tools>system restore> next> choose date> next....>system will automatically restart and reset your computer back to the date you have chosen. Just make sure that you choose a date when all was working ok.
Posted on Feb 16, 2008
I just installed win7 and all mi icons are big, everything is big, please help me.
Right click on the desktop and go to personalize. Down in the bottom left corner click Display. Choose smaller 100%. If this is already checked, Right click on the desktop and click screen resolution. Pick a higher resolution and click apply. The higher the number the smaller everything will get, For Example. 1280x 720 is much smaller than 800 x 600
Mar 12, 2011 | AOC LM560 15" LCD Monitor
How do I reduce the screen size? Everything is appearing too big, especially in my web browser.
Your screen resolution might be set to a lower setting.To make the content on your screen
smaller,you need to set a higher screen resolution.Please follow the instructions on the following link to
do that.
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
Nov 27, 2010 | Compaq FP 7317 17" LCD Monitor
Cannot see all of IE at one time. Have to use
Go into Start >Control Panel> Display or Personalization (XP-Vista).
Find Display Settings and then look for resolution. Change the resolution up a notch (higher numbers) and look at the screen. If you like it, save the changes, if not, change until you like what you see on the screen.
Nov 21, 2009 | Dell E173FP 17" LCD Monitor
The screen and everything on it is enlarged very big and even after changing the settings and doing a system restore it won't change
CHANGE RESOLUTION OF YOUR MONITOR. RIGHT CLICK ON EMPTY DESKTOP, SELECT property, SELECT display, AND resolution. INCREASE RESOLUTION TO 1600X1200 OR SIMILAR. PROBABLY IT IS SET NOW AT 800X600.
Oct 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
Can't get power point to project on sanyo pro xtrax
sounds like it could be a problem with the output resolution of the computer. some projectors will not be able to display anything higher than 800x600, and most computers now can output at a higher resolutions. check the limits of the projector and change the the display on the computer by right clicking on your desktop and going to properties >settings >screen resolution.
Oct 13, 2009 | Sanyo PLC XU35 Multimedia Projector
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Source:
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
Aug 25, 2009 | Hansol Computers & Internet
Screen resolution on powerpoint cannot be locked at high res. Changes when connected to my projector. Monitor screen res. also changes everytime the projector is plugged in, In power point display (2nd...
I just checked the specs on your Benq PB 6110, which has a native resolution of 800X600 and will simulate 1280X1024. When you connect it to your computer, the computer goes to 800X600, right? That is the resolution of the BenQ. How high a resolution do you want? THe highest I have seen in projectors is 1024X760, which is not that much higher. Projectors seem to lag behind monitors and Plasma/LCD/LED TVs for resolution. They must have a very small market share therefore low developement.
May 07, 2009 | Microsoft Office PowerPoint Home and...
We can't get our screen resolution back to what it was (1024x768) it changed when a game being played ended. It runs on 800x600 at the moment and everything is too big.
Screen Resolution
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Aug 05, 2008 | Computers & Internet
Trying to scan and I get message saying to change display setting to 800x600. How do I do this?
Right click on your desktop, go to properties. On display property click on settings then change the screen resolution to 800x600. hope that help get back to me if that error persist.
Apr 19, 2008 | Office Equipment & Supplies
Compaq Presario 1200 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
