Question about Panasonic SC-HT995W System
Panasonic SA-HT740 When I press power F61 Apears What should i do? F61 error on my system
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Posted on Nov 02, 2008
Using AC1603 description as a guide, I had success in eliminating the F61 err code. An additional step I took was to peel off the label (very carefully keeping it in one piece) and apply 1 drop of WD40 to the exposed 'bearing' that is under the label, being careful to only apply the wd40 to the bearing area and not the flat portion where the label will be reapplied too. Listening to the music now.
Posted on Dec 13, 2009
The F61 fault means the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new. Although I have the SA-HT995 system, it sounds like the same fault.
Still under warranty? Get it fixed for free....
Posted on Aug 23, 2008
3 Suggested Answers
SOURCE: Panasonic SA-HT740
I get this error usually once during a movie. Sometimes it is 10 minutes into it, sometimes it is an hour, and the only thing I have ever been able to do to get it to work, is to unplug the black power cord from the unit, for 20 seconds, and then reconnect it, and it usually works for the remainder of the movie. Would like to see a better fix, however!!
Posted on Oct 09, 2008
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
www.pstc.panasonic.com/Epartr/PartsDone.asp
P/N. L6FAJCCH0007 FAN MOTOR (THIS IS THE REAR FAN)
P/N. L6FAYYH0001 FAN UNIT (THIS IS THE SIDE FAN)
Hope this helps
Scott
Posted on Jun 09, 2009
Panasonic f61 output
If what you identify as the output IC has failed, one or more speakers would be affected.
Nov 23, 2013 | Panasonic sa-ht930 Home Theater Audio...
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
Nov 19, 2017 | Panasonic SC-HT740 System
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
PROBLEM F61 ON MY EQUIPMENT AND SHUT DOWN
You possibly took out the output ic by crossing speaker wires or touch one to the case when the other was in the terminal. (turn off and unplug when moving speaker wires)
Before taking it in remove all wires unplug power cord wait 30 seconds and plug just the power cord and turn on. If it still goes to f61 it's going to most likely need the output ic replaced.
$70-90 labor and about $100 for the part.
Nov 11, 2009 | Panasonic Home Theater System System
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
Feb 28, 2008 | Panasonic SC-HT740 System
Panasonic SC-HT995W System Logo
1,731 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
