Question about SanDisk Sansa Clip MP3 Player
My scandisk sansa clip mp3 player is fozen at the refresh database screen
I put some songs on my scandisk sansa clip mp3 plaer and after i took it out of the usb port it says refresh data base but wont do anything and when i turn it off it goes back to its normal sceen but no songs and i put it back on the usb and it says the sons were there so i erased them and then took it off again and it does the smae thing please help
  • 7 more comments
  • ace16 Feb 16, 2008
    got to reset all and format and it is gone
  • Abhishaik Vykanti
    Abhishaik Vykanti Mar 25, 2008
    how do i reset my sansa scandisk 2GB MP3
  • tigger3335 Jun 03, 2008
    i can't put any more music on it
    when i disconnect it it dosn't refreach but the computer says it is still on there
  • Anonymous Aug 29, 2008
    how to u reset the player?
  • becky29r Sep 04, 2008
    i download music to the mp3 than when its removed, it stays on refresh database and i can even go to the main menu or listen to songs
  • Nickman92 Sep 12, 2008
    My sansa clip is frozen at the "Sandisk Sansa" menu. How do I reset it?
  • nicole9 Sep 13, 2008
    I hooked my Sansa Clip up to a MAC to charge and now all it says is Refresh Database. I can't even find it when it's plugged up to my computer. HELP!
  • Anonymous Sep 13, 2008
     this sansa clip  sux!!!!!  it gets stuck in refreshing database  every time  music its uploaded. I just got it  ... this gonna go away?!?!?
  • Anonymous Dec 12, 2008
    every time i hook it up to the computer it shows everything then when i try to format it loads all the way an then says the format could not be complete
I actually called the 800 sandisk number and the guy was helpful (after some annoying personal questions).
Unplug from your computer
Turn off the device.
Push the button down to be in the "Hold" position
Press down on the "center" button (inside the circle)
While still pressing on the center, plug in the device.
Now you should be able to see the device under "My Computer"
Right click on it and FORMAT --YOU WILL LOSE ANYTHING THAT WAS ON IT! But you will be able to use it again. I was assuming all my stuff was gone, it was just copies from my computer anyway.
This worked for me and now I just have put my music back on it.
Hope this helps everyone else! And don't hook it up to a MAC!! Even just to charge it!
Posted on Sep 15, 2008
  • 8,596 Answers
Reset the device first by holding in the power button for 15 seconds or longer.
If this fails, download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Posted on Feb 19, 2008
  • a_grover Feb 10, 2011
    Thanx a million. Was putting on music for my husband (music I do not like at all), and then it was sstuck on the refresh database position. My husband accused me of "purposly frying" his darn thing. Thanks to you guys I will have a peaceful evening (because he will have his headphones on and not bother me)! Thanks again!!!!
My Sandisk Sansa was stuck in the Goodbye position. Could not do a thing to restart. Pressed and held the Power Button for awhile and it fixed it.
Thank goodness.
Posted on Nov 20, 2010
    Problem Solver:
  • 8 Answers
What I was told to do when my Sansa clip froze was this: slide the Power Button up and hold it for approximately 15 seconds. This is like a power down of the device. Once you
perform the reset, the adjustments you made during the last operation will be gone.
Not sure if it'll help, but it's worth a try.
Posted on Apr 20, 2009
My remedy for this situation is safely unhook your sansa clip first, using "safely remove hardware". unplug the thing, turn it off by sliding up the power and hold it for 5 second till the "goodbye" text appear, hook it back to the PC, safely remove it, and unplug it again. It works everytime for me.
Posted on Sep 14, 2008
How to install a SanDisk?
Posted on Aug 31, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
Clip won't restart -dead?
it sounds dead to me
is there a master reset or anything on there?
i dont have oone myself but i have similar things
Freezes at refresh database screen
Update the software else do a format. Make sure ur system is free from virus and other malwares.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | SanDisk Sansa Clip MP3 Player
Database not refreshing, Could not listen the new songs added
go into your menu go into veiw all songs then go to play all
May 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
How do you refresh database?
This just means that the player is refreshing the songs on the list, it does not mean that you have to do anything.
Feb 02, 2007 | SanDisk Sansa e250 MP3 Player
Sansa Scandisk e205 refresh Database failed help plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay, heres wut u can try. try to switch the USB mode from MTP to MSC (in settings, go to USB Mode and switch from MTP to MSC.) And then in the MSC mode connect it to the PC. I dunno bout ur sansa, but my did a Database Reboot, and the computor could see the player. Then u can switch it back to the MTP mode (czu its much mroe comfortable). Although i think the 0.5 gigs are lost forever (i lost 1.5 gigs,)atleast now u can dwonlaod songs on ur player.
Sep 28, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
3,992 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
