Husqvarna 28cc Gas Line Trimmer Logo
Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unsure on correct way to reload spool with line
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
232
Points
vince janis
Level 3:
  • Master 718 Answers
  • Posted on Jan 30, 2010
vince janis
Master
Level 3:
Answers
718
Questions
Helped
256312
Points
1742
Go to smalleng.com they might have a video on how to do, what you need. Check it out awesome website!
How do you reload the string trimmer on a t430 Ryobi 4 cycle push weed trimmer
Found this previously posted:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
How to take reel apart to reload line
Hi Karen:
If this is a fishing reel, pull off the old line into a plastic bag or wind it on to an old spool so it can be safely discarded. Tie the new line on to the reel, and wind the new line on.
There used to be a closed face spinning reel that you would unscrew the face cover to access the spool.
If this is a weed eater, grass whip, some of the older units had a threaded centre with a left hand thread. Once unscrewed, the spool lifted off and you could wind on the new cutting cord.
Happy fishing, or gardening.
2helpful
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 • Garden
1helpful
Echo string trimmer string reload
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,don't forget to give 4 thumbs up,any comments welcome,thank you, ``
Feb 15, 2012 • Echo Garden
I have a craftsman weedwacker model 257 799750 and need to know if I am putting the spool on correctly. Is it the spring then the spool then the cap or the spool then the spring then the cap. when I put...
Spring, spool then cap....if that way doesn't let the line out correctly, then it is possible you have wound the line on the spool in the wrong direction. Try taking the line off and winding it on the other way.
2helpful
Reloaded string empties and shreds continuously in seconds
It sounds like you may need to replace the head. It is designed to advance and stop, but your's isn't stopping. Try this: Clean the inside of the head and connection to the machine well. Put some graphite inside the spool and where it connects to the machine; be generous with the graphite. Put the head back on with some line properly wound onto the spoo (note arrows on back of spool). With the machine off tap the head on the ground enough to disperse the graphite thoroughly in the head. Now, push the head as though to advance the line, and pull on the line. If it advances a little and stops, it is working. Do this several times to be sure. If you can get it working like this, you're good to go. If not, replace the spool. Even with the new spool, occasionally put some graphite in it to keep the line advance smooth!
Best regards, --W/D--.....Please feel free to rate this solution. Thanx!
RLT-5030AH LINE TRIMMER HOW TO PUT LINE ON SPOOL?
You need to prepare two lines of the same length. Wind the bottom one first. place the end of the line in the slot provided. Wind the second spool and place the line in the opposite slot. feed the lines through the two holes provided, be careful to allow the lines freedom. Insert the spool checking to see that the lines do not get pinched. You are now ready to GO!
1helpful
How do I insert sring into trimmer
1. take spool cap off;
2. take your spool out of spool housing;
3. reload line on the groove of your spool;
4. final, get it back.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
