Question about Kitchen Ranges
GE Kitchen Range
GE Meallion 850 Kitchen Range
digital display is not working
have check fuses and they're fine.
Problem is we can't tell what temp the oven is at or the time, timer....
Buy a new Stove. GE stands for Generally Expensive to repair!!!
Posted on Oct 22, 2008
    President:
  • 1,314 Answers
Have you tried clock then setting it
Posted on Feb 16, 2008
Ge tru temp range, oven will not shut off
You have a malfunctioning oven switch,get it replced or simply remove the fuse for your oven there maybe 2 fuses.
Jan 30, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven quit working burners and digital display work fine
Check to see if the coils are properly connected. If so, you may need to replace the thermostat unit, which monitors the actual oven temperature. Hope this helps.
Jul 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Burners and broiler work, but oven doesn't
If the broiler is working then the element is good. The T-stat controls the oven temp. Have you checked it?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Stoe digital display not working
toronto.kijiji.ca/ f-oven-buy-and-sell-home-appliances-W0QQlangZenQQisSearchFormZtrueQQCatIdZ107QQKeywordZoven
www.buysell.com/classifieds/Results/GTA_Ontario/ 926/1/false/sbName+r+subclass+1_Pg+rw/Appliances.htm
I think you display needs replacing.
Above are two links to used ranges of your model.
You may be able to just get the display from these people.
One of these is free.
Otherwise you probably are going to have to buy a new display.
Feb 16, 2008 | Kitchen Ranges
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
May 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
339 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
