Question about Kitchen Ranges
Stoe digital display not working
GE Meallion 850 Kitchen Range
digital display is not working
have check fuses and they're fine.
Problem is we can't tell what temp the oven is at or the time, timer....
  • 552 Answers
Toronto.kijiji.ca/ f-oven-buy-and-sell-home-appliances-W0QQlangZenQQisSearchFormZtrueQQCatIdZ107QQKeywordZoven
www.buysell.com/classifieds/Results/GTA_Ontario/ 926/1/false/sbName+r+subclass+1_Pg+rw/Appliances.htm
I think you display needs replacing.
Above are two links to used ranges of your model.
You may be able to just get the display from these people.
One of these is free.
Otherwise you probably are going to have to buy a new display.
Posted on Feb 16, 2008
Bake does not work
you need to call a repair service we do not recommend DIY with gas appliances.Safety reasons
Nov 02, 2017 | GE JGSP23 Gas Kitchen Range
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Does GE Spectra JBP68 have a fuse? Only 1/2 of range is working.
Your GE Spectra does NOT have a fuse, but it has a electronic control board, as well as elements. If both your elements heat up at all, then they are good. If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service we can discus the issues with your range and I will attempt to get you back up and running again soon.
You may contact us from 7 AM until 9 PM CST Monday through Saturday for appliance assistance and parts.
We look forward to working with you.
Nov 10, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Sep 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Nothing on rage works
Open the control panel and check all connections inside. Look for loose/burned/corroded wires and connections. Plug the range back in and use a wooden spoon, move all wires individually with the wooden spoon until a light comes on. Check out whatever the wire goes to for a bad connection.
Jun 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven, oven light and oven led display will not work
that sounds like an erc[electronic range control] or clock timer etc. You can check power supply to it but chances are thats what you need.
May 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Dec 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Kitchen Range
have you tried clock then setting it
Feb 16, 2008 | Kitchen Ranges
Kitchen Ranges Logo
363 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
