Question about Kenmore 15899 Built-in Dishwasher
Lock light on
The lock light is on and we tried holding the no heat button for 4 seconds to turn it off but that does not work...what can we do?
  • KARENRITA73 Feb 17, 2008
    we unplugged the dishwasher overinght and when we plugged it back in the lock light was still on.
    the lock light is right above the no heat button. But while the lock light is on nothing else is working. Inside of the door it says to unlock the controls hold the no heat button for 4 seconds. We have tried over and over and nothing works.
  • ILKNUR May 11, 2010
    Good evening friends, I need your help. My Kenmore dishwasher's buttons are not working. The -lock- button keeps flashing and the manual says to hold the lock botton for few seconds and it will un-lock itself. I've done that several times but it will not work. The light goes off but goes back on again. None of the buttons seem to work either. I've called Sears but they require $75 just come in and look and that price does not include anything.....just the estimate. Can someone help me please before I dish out $500 for a new one? THANK YOU IN ADVANCE
    President:
  • 1,314 Answers
Try turning the power off for a few minutes is the lock symbol on the no heat button
Posted on Feb 16, 2008
  • robert samples Feb 17, 2008
    ok we have three possibilities here stuck key on the keyboard Resistance on the key bd ribbon bad circuit board or software the first thing to do is get up to the control there is a mylar ribbon there from the key board to the touch pad at the control there is at the base a plastic piece that holds the ribbon in lift it with a fingernail and pull the ribbon out gently clean it with a pencil eraser check the control bd fuse to see if its open now it doesn't look like a fuse but its right where the power enters the control bd look at the control bd for any burnt resisters or such if all that doesn't work replace the control bd
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
Sep 24, 2015 | Kenmore Dishwashers
Child lock light is on and dishwasher will not start. How can I turn off the child lock? model # KUDS25SHWH1 serial# FJ2811738
There is a button or two with a little lock icon by them. Hold the button in for a few seconds until the lock light turns off.
Aug 03, 2011 | KitchenAid Dishwashers
Lock light is on will not go off. nothing will work
Hold the Air Dry button until the light goes off. or Press and hold the "Heated Dry" button for approximately 4 seconds. The control lock indicator light under the padlock symbol will turn off when the controls are unlocked.But if that is not helping then its faulty control panel.It has to be replaced.Unplug the unit from power outlet for 10 minutes then reconnect and check,if lock light turns off.----------------- Thank you.
Jan 24, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
To turn on the Lock
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore dishwasher LOCK ON light will not stop flashing
is that the button closest to that lock light? if not it may be a button closer to the lock light. if it still doenst work you may have a short
Nov 21, 2008 | Dishwashers
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Lock on button
hold the heated dry button for 4 seconds
May 06, 2008 | Dishwashers
Dishwasher lock key
To prevent a child from accidently starting the dishwasher there is a child lockout feature. Press and hold the Rinse and Hold pad (certain models) or the No Heat dry pad (certain models) for # seconds to Lock or UnLock the controls
Jan 20, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Kenmore Ultra Dishwasher. Model 665.15772990
There should be a button on the machine with a padlock symbol. Hold it down for 4 seconds to unlock it. If you want to lock it again, hold it down for 4 seconds to turn it on.
Jun 01, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore 15899 Built-in Dishwasher Logo
103 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
