Question about Gateway GT4022 PC Desktop
GATEWAY DDR MOTHERBOARD
I TOOK MY COMPUTER TO FRYS ELECTRONICS AND MY COMPUTER MOTHERBOARD IS BLOWN THE COMPUTER TURNS ON I HEAR THE FANS RUNNING AND THE LIGHT ON THE DSL GOES ON SO I KNOW THERE IS POWER RUNNING THROUGH THE COMPUTER BUT ITS DEAD,, WOULD THAT BE THE CHIP OR THE MOTHERBOARD AND IF IT IS MOTHERBOARD WHAT IS A CHEAP REPLACEMENT FOR IT?
  • GATEWAYMAD Feb 16, 2008
    I ACTUALLY THOUGHT IT WAS THE HARD DRIVE AT FIRST ITS 200GB AND I REPLACED IT WITH A 300 GB I PURCHASED AND AFTER THAT I TOOK IT IN TO BE FIXED WHEN IT STILL DIDNT RESPOND
  • 2,336 Answers
I would suggest to check the capacitors that are filtering the 3.3 and 5 volts inside the main board. I've seen a number of PCs that failed because of defective capacitors.
Inspect these parts for bulging on the top or bottom.
Hope this helps.
Posted on Feb 16, 2008
    Sergeant:
    Champion:
  • 317 Answers
I don't think it is the chip, or the motherboard, do you know if the hard drive is still good, cause if it isn't it will also cause this to happen.
My gateway essential 400 cant run newer programs **** *** window 7... or explorer 8... or flashplayer 10... how can i upgrade my computer 2 make it run these programs ? a new hard drive ? or what do i do...
You can add hard drive if your system doesnt have enough space for the new programs. If the new programs installs well but is running slow or not starting, then you will have to upgrade your RAM and for better performance, fix one graphics card suitable for *********** board. If you can spend more, Upgrade *********** board and processor.
Thanks
Sherbaz
Sep 20, 2010 | Gateway Essential 400 PC Desktop
My a1630n will power on, but wont boot up; fans run on high and doesnt seem to send a video signal. What do I do?
I am having the exact same issue at the moment :/ the frys techs i took it to said that it was the motherboard i ordered a motherboard put it in and it did not work so i sent it back got a new motherboard from same place and put it in and it did not work i think someone up at frys is seriously not doing thier job i noticed today that my hard drive does not make any sound at all when my system turns on and it did before i took it to frys so i hooked up a couple of other hard drives i have they actually felt like they turned on but no post had set to master as well i could hear it click on maybe i have a bad hard drive they also tested my computer with a CPU said it was not bad also suspect i have a 500 watt power supply hp claims that it is not rated for anything over 480 i have tried the ram with one stick and with 2 and switching them around i am totally baffled at this considering i paid 80 on a diagnostic that obviously failed and i am left with the same problem and a more upgraded computer lol
Sep 20, 2010 | HP Pavilion a1630n PC Desktop
Serious problem
Hi bigciss22. That means that your computer is turning on but NO booting up. Do you hear any beeps? Because depending on the number of beeps can mean either memory or video card. Open the machine and verify that the memory is tightly inserted. If you use the video card on the motherboard (most likely) I suggest you buy a new video card (you have to make sure the interface is either AGP or PCI (i dont think it's PCIe - PCI express). If you dont want to start swaping components, you will have to take it to a repair shop. I hope this helps and please dont forget to rate my answer. Thank you! :D
Apr 28, 2010 | Gateway 550GR PC Desktop
Gateway profile 3 has power but wont turn on
Make sure that the IO cable is properly connected. To make sure disconnect the cable and reconnect it again.
Jan 13, 2010 | Gateway Profile 3 PC Desktop
Had a power surge... a of my external harddrives work; however, can't get either computer to power on... Gateway GT5654 or my wife's Gateway GT5408.. on my wife's motherboard, there is a green light......
You can get a powr supply for this, but if the surge went passed that and smoked the motherboard then your going to need to replace that as well but a new poer supply should shore this up and you can get them from frys.com,tigerdirect.com you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Gateway GT5654 Desktop PC
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
I have a gateway 835gm desk top
there are a number of things that could be wrong here, firstly reset the cmos on the motherboard, if you cannot find the cmos jumper then remove the battery for 10 minutes (make sure the power cord is removed from the back) press the on/off button a couple of times, this will drain any remaining power from the board and properly reset the cmos, while the battery is out remove the memory, clean the contacts and repace, put the battery back in and connect power, if the machine turns on, job done, if not then it could be something far more serious, check the power suppy if could be faulty, the processor may have blown or the motherboard itself may have blown, the only way to check all the components at once is to get a working motherboard which supports your processor type, the same model would be an advantage
Nov 15, 2008 | Gateway 835GM (835GH) PC Desktop
Computer goes on but does not boot
When you start up the PC, do you get any kind of beep sound? If not, I would reckon the RAM modules are faulty and would need to be replaced first. That is the usual cause for this kind of issue. Also when replacing the modules, make sure they are the type supported by your motherboard, ie DDR, DDR2, etc. You will have to consult your m/b manual for this..
If the problem is not with the RAM, ie you hear a beep, but nothing else, I would guess that the MBR of your operating system is dysfunctional, which would mean that you would have to reinstall the operating system.
Hope that helps...
Cheers!
ID
Oct 28, 2008 | Acer Aspire T160 (AST160UA3400) PC Desktop
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Gateway GT4022 PC Desktop Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
