My X6100 series printer is not working properly. I put in a new black cartridge and find that the alignment of the cartridge carrier is not lined up properly. When I send to printl, it prints only two thirds on page and bangs on other side. What can I do to rectify this?
  • mam1934 Feb 19, 2008
    I have not been able to align my cartridges
    after following my Lexmark 6100 series
    user's guide. 2/19/08
  • 19,396 Answers
Sounds like your printer has a major mechanical problem. You can try doing an alignment using the printer software. I don't think it will solve all your troubles, but is the first thing to try. In any case here is the link to all the library provided by lexmark for your printer.
Cheers
Posted on Feb 16, 2008
  • 549 Answers
If you have an instruction manual, it will give you directions about how to align the printer.
You can access the driver program in your computer.
There should be an icon on the desktop or go to the start menu and chose the program for your printer from there.
You will see when you bring up the program, how to troubleshoot and tweek it.
I just put in a brand new black ink cartridge. The alignment page doesn't show the black ink and the printer kept saying alignment error
It could be that one of the cartridges is not seated properly in the cartridge carrier. Try to re-seat the cartridges in the cartridge carrier.
Aug 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
I just got a new black ink for my Lexmark X6150 printer and when I did the alignment test, it turns out a like dark grey instead of black. The printer also said to remove tape from ink but all the tape has...
You should try cleaning your cartridge nozzles. If you're using Windows, go to Start -> Programs -> Lexmark X6100 Series -> Lexmark Solution Center -> Maintenance tab -> Clean to fix horizontal streaks. The printer will then print a test page.
You can also manually clean the cartridge nozzles. Follow the steps in this article : How to Clean the Print Cartridge Nozzles and Contacts Manually.
Thanks.
Feb 10, 2011 | Lexmark X6150 All-In-One InkJet Printer
Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
Alignment problem on lexmark x4650 printer
Try this
Turn off you printer
remove the cartridges
and try gently moving the ink cartridges carrier from left to right
for about a min.
also you can try to wipe machine oil on the bar that holds the ink cartridge carrier
then put the cartridges back inside the carrier
then turn on you printer
and try to print again
If problem persist
TRY THIS:
turn off your printer
unplug the power cable from the printer
lift you printer and put it in an upside down position
then shake the printer from left to right
see if there's any foreign objects stuck inside the printer
Feb 25, 2010 | Lexmark X4650 InkJet Printer
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Alignment problem hardware error 0502. Printer is an X6150.Can n
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press the "Options" button 9 times. "Maintenance/Align" should now appear in the display screen.
2. Press the "Right Arrow (+)" until "Test" appears.
3. Press "Select."
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about a 1/2-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please contact Lexmark tech support for further assistance.
Oct 01, 2009 | Lexmark X6150 All-In-One InkJet Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
Alignment problems
Try this using this link:  http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:383:0:0&framed=&docid=ENUS18888&relevance=1
or to dowmload the  manual :http://www.lexmark.com/publications/eng/x6100/index.html
Apr 07, 2008 | Lexmark X6170 All-In-One InkJet Printer
Error C50 on Lexmark X6170 printer
The ultimate permanent fix for the x6170 printer would be to purchase new cartridge snap-down levers (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). If you purchase snap down levers for a Lexmark printer series X5100 or X6100 or Z55 or Z65, the little guide peg inside the snap lever would work with an unmodified 83 and 82 Lexmark cartridge. All Lexmark did for Dell to make the Dell unique, was to put special Dell snap levers on the printer. I considered breaking off the little guide peg on the snap lever, but decided against it as it appears to help hold the cartridge in alignment
Mar 08, 2008 | Lexmark X6170 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
