Question about Mitsubishi VS-60707 60" Rear Projection Television
Mitsubishi rear projection tv problems
Our mistubishi tv (rear projection) is 8 years old and about 1 1/2 hours after being turned on, wiggly horizontal lines appear for about an hour. Then it goes away and is fine the rest of the time until the next time we turn it on and after another 1 1/2 hours it starts again. Everyday and almost always the same amount of time. Any suggestions?
  • Megbee Feb 20, 2008
    sounds expensive to call a tech? Do you think it is worth trying to fix? How much are techs these days?
    Sergeant:
    Champion:
  • 301 Answers
This problem is going to be several bad capacitors on the signal board inside your tv. i suggest calling a technician
Posted on Feb 20, 2008
  • MATT BECKER Feb 21, 2008
    well there are going to be about 11 or so capacitors on the signal board( board on left looking at it from the back). all of them arent going to be bac but i would suggest replacing them anywho. it is somewhat easy job if you had the tools and ambition to replace with the same value capacitors. i just suggested a tech fix it because it is an older set and who knows what else could go wrong. but the usual repair cost would be around $200-$400 for most places
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
I have an 8 years old rear projection TV. Try to
May be a short. Contact tvrepairkits.com and see if they help diagnose it further.
Feb 19, 2010 | Televison & Video
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
TV won't turn on - front panel light keeps blinking
Thats a common problem when the Caps on the DM are bad the set will continue to operate as long as it doesnt get unplugged, once the plug is removed from the wall then the dM cant complete the boot sequence again untill the caps are replaced. Its a very easy repair and the repair kit is very cheap and comes with step by step instructions. Here is a link to the repair kit for your model
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 27, 2009 | Televison & Video
Intermittent vertical jitter on mistubishi tv 65000
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Jul 21, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Reasonable Price Quote for Repair?
Good Day;
In my estimation you paid too much the first time. The TV is 8 years old, buy new TV. The average cost is about $650.00.
May 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
TV won't turn on!
Less then 2 years old and the AUTHORIZED repair place wants 900 to fix?>?? sounds like a rip is about to happen I would call up Mistubishi and give em hell!!!!!!! Call them at 800-332-2119 or file a complaint at CustomerCare@meus.mea.com Good Luck
May 25, 2006 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
369 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
