Question about Whirlpool GH7145XF Microwave Oven
No Heat Our microwave will not heat any items we place in it. It functions properly in every way with the exception of not heating the item. Is it the magnetron?
  • w-barryan Jul 18, 2008
    no heat problems
  • Whirlpool Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
I would first suspect a failed door switch or loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 27, 2008
  • 2,336 Answers
Most likely is the magnetron that failed. This is very common problem with microwaves.
Check the user manual under warranty, sometimes the magnetron has 5 years warranty.
Posted on Feb 16, 2008
How do I get the heat to work?
Hi Marc, there is no 'heat' per say with microwave ovens as one would find in a convection oven. Microwave ovens operate by generating electromagnetic fields (within the microwave band) that causes water molecules in the food item to vibrate/rotate creating friction/heat - within the food item as opposed to the surrounding space (this would be convection)
Oct 26, 2014 | Oster Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
Power is on and all seems to be functioning except just today it does not seems to generate any heat. Any item placed in the microwave remains cold.
The most likely problem is the magnetron, also the high voltage capacitor and diode can be a factor. If the magnetron proves to be the issue you are further ahead replacing the microwave oven.
Mar 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1650cb003 has power to unit, fuse is good, all items function, but will not cook or heat items
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JVM1650 all the functions are working except items do not get warm/hot
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1870 it won't heat anything, all other items work
Ok, if this unit has stopped heating, this will confirm a major fault within the Magnetron. this device is responsible for the heating affect and, you will need to replace this damaged part in order to restore proper heating functions in you microwave oven.
Mar 03, 2009 | GE JVM1870 Microwave Oven
LMV1630 doesn't heat
check control panel circuit, and related circuit.
Oct 27, 2007 | Microwave Ovens
GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Aug 04, 2007 | GE JVM1650SH Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
91 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
