Question about Logitech Webcam
Webcam Speakers Echo and Double Feedback
While on my webcam I hear feedback on my own voice and echo.
  • 1 more comment
  • muiris Mar 09, 2008
    How do I avoid hearing an echo?
  • Anonymous Feb 20, 2009
    When on the laptop webcam there is a tremendous amount of "screeching" similar to feedback noise on a michrophone. It intermittently comes and goes
  • Anonymous Mar 07, 2009
    noise and feedback from webcam on a new dell vestro 220 computer
  • 818 Answers
"Noise", as used in this document, is a general term referring to any sound a speaker system makes that is not part of the original source material. There are many different types and sources of noise, each with its own solution. Below is an explanation of the common types of noise, what causes them, and how to minimize their occurrence.
Hum or Buzz
There are four common causes of humming and buzzing:
  1. Sound card If the humming or buzzing gets louder or softer with changes in the volume setting, this is an indication of noise coming from the sound card. In this case, check all of the connections to the sound card to make sure they are all completely plugged in and secure. Then, adjust the level setting of the sound mixer to obtain the best performance. Generally, you should leave your CD volume settings in the mixer at full and reduce the sound card's master output level down. For information on doing this, please refer to your sound card manufacturer's documentation.
  2. Unused input cables If you are not using all of the source inputs to your speaker system (such as using a 5.1 speaker system with a 4 channel sound card), the unused input cables will pick up noise. The solution is different for each speaker system, as described below:
    Z-540 / Z-560 (2 channel sound card): Depress the M3D button.
    Z-640 (4 channel sound card): Depress the Matrix button.
    Z-680 (2 or 4 channel sound card): Disconnect the unused input cables from the control pod
  3. High-power devices If you are using other high powered devices on the same electrical circuit, they may be causing hum or buzz. If so, discontinue their use while you are using your speaker system. Examples of such devices include microwave ovens, halogen lamps, power tools, etc. Also note that high-power devices with dimmer switches (such as halogen torchiere lamps) will cause an especially pronounced buzzing effect. To minimize hum or buzz, make sure that the dimmer switch on these products is either all the way on or off.
  4. Electric Polarity In many countries, the US being one, the electrical power grid is polarized. In these countries, the power plugs are designed so they can only be inserted into the wall socket in a single direction. For example, in the US one of the plug blades is larger than the other. To avoid humming and buzzing, both your computer and speaker system must be properly plugged into polarized outlets. If your wall outlets do not have polarized plugs, as in the case of many older homes, and you are using adapters to plug these power cords into the wall, it is possible that the polarity of either your computer or your speaker system is reversed. In many other countries, such as most of the European continent, wall sockets are not polarized at all - making it even more difficult to properly match the computer and speaker system. To solve the problem you will need to remove the power plug from the wall outlet, rotate the plug 180°, and re-insert it into the wall. Try this for your speaker system power cord, your computer power cord, or both. You should be able to find a combination that will eliminate the humming and buzzing.
Pops and Clicks
There are three main causes of pops and clicks:
  1. Sound Card Many pops and clicks are created by the sound card. There are two common causes: sound card quality and older or mismatched drivers. If the overall volume level of the pops and clicks goes up and down as you change the volume on the speaker system, the noise is being generated by your sound card. Lower quality sound cards don't include the necessary circuitry to cleanly remove noise from the sound output. Logitech's higher-powered systems, such as the Z-560 and Z-680, are also sensitive to the overall quality level of the sound card. If you are using an older or lower quality sound card, we suggest upgrading your sound card. The other primary cause is older or mismatched drivers. Make sure you are using the latest drivers for your sound card.
  2. Multi-tasking If you are running more than one program on your computer that accesses the sound system at the same time, small pops and clicks can be common. This is a function of your computer and/or sound card. A common example is using a program that generates occasional audio feedback (such as beeps or other sound effects) while listening to an MP3 track in the background. The solution is to turn off audio feedback in the first application so that the background MP3 track is uninterrupted.
  3. Interrupts in the Digital Bitstream On digital systems, such as the Z-680, it is normal to hear a very faint "tick" when you switch between inputs (by pressing the input button). You may also hear louder 'clicks' or 'pops' on a device such as a standalone DVD player or a sound card if it is plugged into one of the digital inputs. On some systems, this noise may occur when skipping tracks, switching audio streams (for example, from Dolby Digital to DTS), or navigating a DVD menu. The clicks and pops occur because the device is sending out an interrupted digital data stream. This behavior generally occurs with older software and older players, but is uncommon on most modern equipment. The Z-680 has been extensively tested with the latest sound cards, software DVD players, and standalone DVD and CD players. If you experience extensive popping and clicking, we suggest upgrading to the latest version of your software DVD player or, if using a stand alone device, trying a different speaker model. If you need more assistance with this issue, please contact Customer Support.
Stutter
A stuttering sound track is an indication of either insufficient or conflicting computer resources. Check to make sure that your computer has sufficient processor power and memory to handle the applications you are running, especially if you are using a software DVD player. Defragmenting your hard drive may also help. If you are sure you have sufficient resources, check to make sure that you don't have any conflicting IRQ or DMA channels.
We have also seen some software DVD player/sound card combinations that cannot properly output a Dolby Digital or DTS signal through the sound card's S/PDIF digital connector. (S/PDIF is a generic term for either coax or optical digital connections.) The result, when using a Z-680 hooked up to a S/PDIF connector, is a stuttering soundtrack. As mentioned, this stuttering is caused by the computer, not the Z-680 speakers. Switching the software DVD player's sound output to the 5.1 analog outputs will generally solve this problem.
Hiss
All high-powered amplification devices - everything from multimedia systems to home theater systems to movie theater sound systems -- generate some level of background noise, or hiss. In addition, low quality sound cards with poor signal-to-noise ratios can generate a significant amount of steady hiss that is reproduced on the speakers. Under normal conditions at a normal listening distance, the hiss coming from the sound system should not be noticeable. In a very quiet room, or if you place your ear very close to the speaker, you may hear a very low level hiss. This is normal, but should be completely masked by normal music and game sounds.
If you find that hiss is noticeable, it is likely that the speakers are too close to your listening position. If the speakers are too close, you will not obtain the best imaging of the sound and you risk damage to your hearing when the system is playing at full power levels. Try moving the speakers further away from your normal listening position. We recommend at least 18" for the moderately-powered systems (such as Z-340, Z-540, and Z-640) and at least 30" for higher-powered systems (such as the Z-560 and Z-680).
Also, note that the satellites in most Logitech speaker products are designed to be wall-mounted. Wall mounting the speakers provides two benefits: 1) it moves the of the satellites further away from your listening position, making any hiss less noticeable and 2) it moves all of the satellites further away from each other, providing better channel separation and surround sound spatialization.
Posted on Feb 29, 2008
Echo and I keep hearing my own voice
Sounds like 'feedback' - where your contacts mic is picking up your messages and sending them back
Try your contact with a set of earphones
Jan 29, 2010 | Logitech Webcam
Mic Echoes
Echo is caused by a number of variables. Are you in a large room with mic extended away from you? Mic too far away will create echo. Also try turning down the gain for the mic
Jan 22, 2010 | Dynex Voice-Certified PC Desktop...
Audio feedback/echo when using LifeCam.
hi
go to the setings of the webcam and select audio options, fix it from there
i hope it will work :)
Jan 09, 2009 | Microsoft LifeCam VX-3000 Web Camera
Quickcam E3500
That's because they are using their speakers to lesson to you. If you both use headphones then you won't get the echo. Also you can have them try to lower the volume at their end.
Hope this helps.
Dec 18, 2008 | Logitech Webcam
Video conversation ECHO/Feedback
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 04, 2008 | Logitech Webcam
Echo
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Mar 04, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Terrible feedback sound
sounds like maybe you have two microphones running at same time?
Feb 25, 2008 | Microsoft LifeCam VX-3000 Web Camera
Awful High-pitched Noise and Echo Feedback
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Echo when using HS850
It might be a problem with their sound setting. If their speakers are on while using the mic, they might get some feedback that could be the cause of the echo. They may even just have to tweak their mic settings (through the control panel sound options or their soundcard options).
Jan 06, 2008 | Motorola Mobility HS850 Consumer Headset
Echo
Try the following: Go to the Control Panel (in classic mode). Open Sound devices. Change tab to Voice / Microphone. Press Test Software. Wait a couple of seconds. A small guide begins now. The problem is that the Microphone volume is set to high. Try to adjust these settings and see where it gets you. Usually does it for me. Also, try to not have the mic near the speakers. (I translated the steps from my swedish version of XP, look for similiarities.)
Apr 03, 2007 | Logitech QuickCam Fusion 961403-0403...
Logitech Webcam Logo
2,665 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
