Question about Black & Decker AS150 Iron
How I can fix The Black&Decker digital advantage that does not heat
When i plug in the B&D digital adventage Iron the pilot is I try to increase the heat but does not heat.
  • Anonymous Feb 29, 2008
    how do i open a black and decker d2020 iron
  • Mohammed Lawal
    Mohammed Lawal Mar 20, 2008
    1. I do have a new b&d digital iron which ihave use only once that it works and the second times usage no heat.The digital control indicator is working but no heat. So what should i do?
  • 549 Answers
The iron will probably have to be taken apart.
If you are handy, you can do this when unplugged.
Check for broken connections and anything that is obvious like burned smell etc.
Posted on Feb 16, 2008
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How to fix a Black and Decker Iron?
irons are not meant to be fixed due to their construction. the cost is generally more than a new one ( if you could get the parts)
take it to an appliance service centre to determine exactly what is the fault but be prepared for a "new one" answer.
May 08, 2014 | Applica Black And Decker Steam Advantage...
How do you replace the cord and or dismantle a Black and Decker Digital Advantage Iron
have this done by an accredited appliance service shop as it is not a job for beginners.
Feb 19, 2014 | Applica Black And Decker D1500 Digital...
The steam wheel on black and decker digital advantage is stuck in the no steam position
This problem developed with our iron within the last week. Playing around with it today, I discovered that the dial WOULD respond to "persuasion". I forced it, and it cooperated. Find somebody with a stronger grip and try it.
Aug 03, 2013 | Black & Decker D2020 Iron
Instructions for steam clean on B&D iron
http://useandcaremanuals.com/pdf/D1200,D1500,D1600,D1650997.pdf
Or http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4
Hope this helps you.
Aug 01, 2010 | Black & Decker Irons
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Jan 12, 2010 | Black & Decker D2030 Iron
Stopped heating
I work for Black & Decker. Any part that someone is telling you to purchase for that iron isn't from Black & Decker. Their irons are no designed to be repaired. If the iron is no longer heating, it needs to be replaced. Please call our customer service department at 800-231-9786 so that we may determine your warranty status.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 20, 2009 | Black & Decker D2030 Iron
Need the repair manual for a black and decker digital advantage iron. I will turn on but will not heat. rmsc
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the iron isn't heating, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Please let me know if I can be of further assistance.
May 04, 2009 | Black & Decker D2030 Iron
Does anyone know how to open a Black and Decker digital advantage iron? - I suspect a loose connection where the power cord attaches to the iron and have taken the two screws out of the back plate but the...
I think I have the solution now!
First of all, remove the temperature knob. Than remove the temperature indicator (it's like a little disc). Theres a hidden screw under the temperature indicator! Remove that screw and continue with your fixes.
I hope it could help you.
Jardel
p.s. - Sorry for my noob english...
Sep 21, 2008 | Black & Decker D2030 Iron
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker AS150 Iron Logo
374 people viewed this question
Top Black & Decker Irons Experts
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
