WIRELESS LINK FOR SKY+ BOX
I BORUGHT A WIRELESS CONNECTION FOR MY SKY+ BOX BUT WHEN I SWITCH IT ON THE SKY PICTURE DISAPPEARS FROM THE SENDER TV AND WHEN I GET IT BACK ON ANOTHER CHANNEL THE SOUND GOES ON NOTH SENDER AND RECEIVER TV.
HAS ANYONE GOT ANY SUGGESTIONS?
THE WIRELESS LINK IS PLUGGED INTO THE SCARTS ON SENDER AND RECEIVER TV'S.
i removed the scart connection coming from my tv into the sky box
i then plugged in the piggy back scart of my philips slv3220 wireless transmitter and switched it on
i then plugged my tv scart that i removed piggy back into the back of the wireless transmitter
i expected the sky picture to reapear. it didn't
i tried the procedure with 3 different scart cables with no success
i passed the unit onto 2 friends with sky plus
they had no problem
i only have sky basic package
Throw it in the bin!
Posted on May 16, 2008
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Samsung ps42a457 picture disappeared whilst watching,sound still present
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Televison & Video
Hi, i have just bought a logik wireless av sender so send my sky signal to the tv in the bedroom. the instructions in the manual are very basic and i cant get it to work. any ideas. on the tv in the...
Red and white are only Audio ports.
IF there is a scart port plug your av receiver into the scart. Take note on which number your on ie channel there should be several numbers you can choose on your tx/rx then go down stairs to your sky box and ensuring that you are on the same number as the one upstairs.
Then just plug it into the back of your sky Box.. the number on your sender are incase your getting interfearance from other sources in the home. have a play with this and see what works best
Hope this Helps
Little Dish Fitter
Aug 22, 2009 | Televison & Video
IVE BOUGHT A LOGIK AV SENDER AN THE PROB IS AFTER SETTING IT UP THROUGH MY SKY DIGITAL BOX TO MY TV UPSTAIRS I CAN ONLY HEAR THE SOUND AN CANT SEE THE PICTURE ALSO THEIR IS A WHITE, YELLOW AN RED LEAD AN...
ok these are called phono leads, yellow = video, red = left sound, white = right sound.
you need one of these http://www.maplin.co.uk/Module.aspx?ModuleNo=13372 there are 2 types, inputs and outputs, this one does both, (you need an output. sky to sender) let me know if this looks right for u
Jun 07, 2009 | Televison & Video
I have a Nikkai A15gy mini wireless TV/video sender, connected from a Sky box, sound is OK, but picture is distorted. The bottom 1/2 inch of the picture appears at teh top of the screen. Have tried...
Hey there Merch12, I had the same issue. I turned it off, unplugged absolutely everything and reset the trip switch in the house and left it over night, the next morning it worked like a GEM hoped that helped you! The same thing happened with my
<a href="http://www.reviewprinters.net/hp-laserjet-pro-m1536dnf-review/">HP Laserjet Pro M1536DNF</a> printer, I used the same technique but it didnt work
Jul 23, 2008 | Televison & Video
Hannspree 32" lc
The only workarounds I have seen, are pull out pin number eight out on your scart lead, this will stop it auto switching, or alot of these wireless video senders block the auto switching features when connected up through the via the scarts.
Jan 10, 2008 | Hannspree (K206-10U1-005) Television
your sky box should have 2 scarts ;input and tv.I have one so as can watch sky upstairs and on projector screen.
reciever sender is in av on tv upstairs sender downstairs is in scart next to tv scart on skybox scart lead in tv scart connected to av on tv.some senders need to be turned on.when you plug in adapter and led is on doesnt necessarily mean sender is on .is this a new sender with instructions youve bought
Jan 01, 2008 | Acer TravelMate 2300 Notebook
135 people viewed this question
 Grubhead
Grubhead
