Question about Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA WF860
MY WASHER KEEPS FLASHING H2O AND THE WASH CYCLE TAKES AT LEAST THREE TIMES AS LONG AS IT SHOULD TO FINISH THE WASH,CAN ANY ONE HELP ME,AND DOES ANYONE KNOW HOW TO TAKE THE TOP OF THE WASHER OFF TO GET INSIDE
  • Anonymous Feb 25, 2008
    Hello my hotpoint wf860p shows error h20 and just keeps feeding in water and doesnt turn anymore just keeps taking in water is there a reset,can you please help?
HOTPOINT ULTIMA WF860 - image_bubbleanswer_04.gif I recently had the same problem with my Hotpoint Ultima WF860P and after some investigations, I found a disconnected tube linked to the pressure switch beneath the top cover was the cause of the problem. In short, this tube forces air to the pressure switch and cuts off the valve feeds.
Andrew Algar - Brighton
Posted on Mar 08, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot
Posted on Feb 22, 2008
Set wash program ,wont start ,there is a tap on display plus it flashes up H2O
H20 means a water inlet problem.
Check the inlet pipe/s are not restricted or kinked.
Ensure that the pressure is adequate.
This cold weather has caused some washer hoses to freeze up.
Hope this helps.
Jan 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima WT960 is in the middle of a program and on the rinse cycle and on the screen is flashing H2O the door is locked with my wool wash inside. What do I do.
Check the program that you have it set on for the wool cycle. Some washers have where you can "add water" in the rinse cycle. If yours has this feature, I would try that also.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
H2o error
I checked everything I posssibly can and ended up booking an engineer who will be here Monday. I'll post what he says and whether or not it's DIY fixable.
Apr 03, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf640
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marfked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight. Post back later if the code stil comes up...........
Mar 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 stops every time with 1 second to go
This problem is caused by the heating element not working.The machine won`t spin & finish because the machine knows it hasn`t heated the water during the wash programe but clock will still count down.this is what we were told by a hotpoint engineer.the callout charge is £89.98 from hotpoint this includes parts & labour. 27/7/07
Nov 05, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
400 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
