Light switches i am replacing all my light switches. I have fitted them all apart from the toilet one.This has the fan wired to it as well.The switch is a isolater switch?&the new one is a single 10amp 2way but when i wire it up the fan is a timed one it goes on when the light is off& goes off when its on (time runs out)can you help
  • 3 more comments
  • dad46 Feb 17, 2008
    there is no black wires there is only 4 reds 2 of which are for the fan. I have got the main live because they have been tied in a loop
    your picture is right but on the new swich i have there is only 3 wiring points com,l1&l2 the old swich had 4 with a bit wire connecting the 2 top (coms?)so when i put the new 1 on i connected the 2 live in the com (instead of the bit wire)the other fan into L2&the lightintoL1 the light& fan work but the fan only comes on when the light is off. If i put the light the fan goes on to timer as if the light is off how it should be
  • Gary Davd
    Gary Davd May 11, 2010
    this is a crude pic but from what you said is this what you have ??
  • Gary Davd
    ok lets take this slowly 4 reds in all 2 go to the fan and 2 go to the light right?? do you know which 2 go to the fan??
  • Gary Davd
    switch the wires (Blacks)
  • 770 Answers
Ok i think i have the pic right now does this look like what you have??
Posted on Feb 17, 2008
I have 2 cooper 600w/va magnetic dimmers on lights and a single pole fan switch on the same circuit. occasionally when I turn the fan off, it will shut off one or both of the lights. Suggestions??
I am definitely not an expert on this sort of stuff but the fan is an inductive load operating presumably on alternating current. At those times when you switch off and the ac is at high potential a very strong voltage pulse can be generated by that inductive load and superimposed on the circuit. I expect that could be responsible for upsetting your lights, either because of that voltage transient or the resulting magnetic pulse.
There could be a suppressor in the fan to combat this that has failed and needs replacing or it could be the manufacturer never expected the unit to be wired in such close proximity to dimmer switches like yours and provided insufficient suppression or if the fan is driven by a simple synchronous motor it might not be fitted with any sort of suppression at all.
There are a variety of commercially produced filters and suppressors available from simple types such as fitted to vacuum cleaners or power tools to more complex ones containing a combination of inductors and capacitors, the main problem apart from deciding which type to choose will be the fact they are most effective when fitted physically close to the load (motor) and connected with short, direct wiring.
You could begin by asking your local tv repair shop to provide you with a couple of suitable capacitors of between 0.27 and 0.47 microfarad with a working ac voltage to suit your mains and connect one between live and neutral at the fan and the other between live and ground. You could connect a third across the switch. These modifications will do no harm and could do a lot towards curing your problem.
Jun 26, 2015 | Electrical Supplies
In trying to light our furnace for the winter, we encountered a flashing red light and control switch open. What do we do?
these type of things depending on heater are usually better for the experts to fix for you i could fix it but not without looking at it first the red light could be flashing for a fault code but that could also be faulty, usually the only thing you could try is reseting the heater by switching of the power feed for a minute, then turn back on the only trouble is it may be wired directly to the mains box without an isolater near heater (thats why its always a good idea to have isolater near heater for quick switch off of power) if reseting it doesn't work i'd would call service agent as it needs repair work
Dec 10, 2010 | Heating & Cooling
I have a hampton ceiling fan and the chain for the light switch is stuck...what should I do?
The chain is easily replaced or repaired, sometimes just a drop of oil will get it slipping again. But the hardware store carries the little pull chain switches , they are a fit all. Turn off the power if you are worried about getting zapped, just take of the wire nuts from the old switch and replace the switch, hook the wires back up just how they were, you should be all set. Check it out.
Jun 22, 2010 | Solar 2-wire Pull Chain Light Switch For...
I have wired a new light fitting into our downstairs toilet however when I came to test it the light worked but half the other downstairs lights are now switched off when the toilet light is swithced off....
Hi
Probably put your family at risk of electricution . By connecting the live cables to earth you have effectivly made all the metal light fittings live. It is amazing that the fuse has not blown, This in itself is dangerous and you should have an electrician look at the wiring.
The correct wiring should be as follows.
Identify cables there should be 2 twin and earth (red black & copper earth) cables and 1 twin red and copper earth. (or 2 single red wires)
connect all copper earth wires suitably sheathed in green/yellow sleeving to earth lug.
Connect 2 black cables to neutral block.
Connect either single red (0r 1 of 2 reds) into live block.
connect remaining 3 reds into loop block.
HTH
Nov 11, 2009 | Kitchen Appliances - Others
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
1997 Mitsubishi TF wagon starting problems
hi ...problem could be automatic transmission start isolater switch linked to gear selector(designed /adjusted not to start in gear),or ignition switch worn..creating electrical resistance and becomes overhot loosing power contact,due to burnt switching faces......so if it happens again,.. handbrake on ! ! and try moving gear selector whilst attempting to start...if this remedies starting ,...it may be isolater switch..if not,... it will most likely be ignition electrical switch at fault...hope this helps
Feb 24, 2009 | 1997 Mitsubishi Galant
Ceiling Fan Light Switch stopped working
I was able to resolve the problem. It turned out that the light fixture part that I had received from the associate at The Home Depot was the wrong one. I needed a 3 speed not a 2 speed replacement part. However, I ended up not even needing that. Once I took the fan apart and watched it malfunction, I could see that the clear part holding the fixture rope on my older fan had another circular piece in the center that had become loose but had not fallen out. I simply used a very small piece of blue paint tape to seal back in place. Since the area doesn't get hot, I found this to be a suitable solution. Thanks for your help.
Feb 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Hampton bay ceiling fan
we have a hampton bay fan burning smell coming in didnot run
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
Wiring p fan speed cotrol switch
most common fanlight control is 2 dimmer switches in parallel to control fan spped and light, direction is still usually controlled on the fan body
requires 3 wire in the light box, and a compund dimmer, this one has left and right and fits a single switch box
where a fanlight is used to replace a regular household fitting there is often only 2 wire in the switch box, either a sparky can fishtape an extra cable along the lamp cable, or replace the wire,
the 3 wires from the fanlight are light fan and neutral
some new retrofit fanlights have remote controls to negate rewiring
Apr 26, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
