Question about HP OfficeJet 6110 All-In-One InkJet Printer
PSC 2115 error message
I have a Hewlett-Packard PSC 2115. When I turn it on I get the message that cartridges need aligning. When I print out the test sheet and place it on the glass and press enter to align cartridges I get the message "aligning cartridges" but nothing else happens and the message continues to show. If I push any other button, I get a busy message.
  • Yellow99 Feb 19, 2008
    Thanks seventonine for your response.
    I will follow your instructions and hopefully all will be well.
    Thanks again,
    Yellow99
  • 72 Answers
Turn off your machine unplug the power for about 5 mins. disconnect the usb cable from back. Plug back in power, wait until machine fully boots up. Check your cartidges to make sure there in there good and are not lose. Remove them and just put them back in making sure there secure. Then try to aline the cartidges.
Posted on Feb 16, 2008
Missing cartridge error message
Please try the following article. It may he resolve you problem.
Print cartridge missing
Other wise Follow Us For
HP Printer Support
Mar 25, 2012 | HEWLETT-PACKARD Hp - DESIGNJET Z3200 24IN...
Tip
What is a Scanner Error 5 Hewlett Packard M2727nf MFP
"Scanner Error 5 or Error 8"
Hewlett Packard Laserjet M2727
The Copier Scanner is failing to initialize or find home position. The printer will have to have the Scanner replaced by an Authorized Hewlett Packard repair facility. The printer may at times "freeze" or "hang".
This printer is under HP Warranty until Mar 23, 2011
Contact Hewlett Packard for Warranty repair. See Link Below
http://welcome.hp.com/country/ca/en/contact/phone_assist.html
2 parts need to be replaced at the same time
Parts Required as follows
Formatter - CC370-60001
Scanner/Flatbed - CB532-67905
Warranty Extension Expiration 2011-03-23
on Feb 04, 2011 | HEWLETT-PACKARD Hewlett Packard 53A...
Tip
What is a Scanner Error 5 Hewlett Packard M1522nf
Hewlett Packard Laserjet M1522
Contact Hewlett Packard for possible Warranty repair. See Link Below
Parts Required as follows:
Formatter CC396-60001 M1522N Printer
Formatter CC368-60001 M1522NF Printer
Scanner/Flatbed CB534-67903
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Keep getting error message from HP PSC 1510 all in one...asking to align, but aligning always fails
For completing alignment both print cartridges need print in good quality.After the alignment page is printing put it on the scanner glass to way as shown on the page and press scan button.If not help replace the cartridges and try again.
Nov 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
I have just installed two new Hewlett Packard printer cartridges and have aligned my printer as instructed. I have printed off the document I need and there ae faint background lnes behind the print. I...
Depending on your version of printer there should also be an option to clean the print cartridge. It is usually listed in the same place as the option to align the cartridge. I would suggest trying the clean process once or twice and see if that helps.
Ill be able to give you more precise instructions if you can get me the model of your printer.
Thanks
Aug 10, 2008 | Office Equipment & Supplies
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
154 people viewed this question
Ben Johnson
