Question about Dishwashers
Connecting the hot water line to a new dishwasher.
When I connect the 90 degree elbow to the water inlet valve the elbow inlet isn't facing the correct direction to connect the hot water supply line. When I back the 90 degree elbow out some to face the correct direction then I get a leak. (Kenmore Model # 665.1384)
  • Anonymous Mar 14, 2014
    hotoint dishwasher hda469m-03ad connect to hot water supply?
    President:
  • 1,314 Answers
Use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Posted on Feb 16, 2008
Dirty Dishes
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 28, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
We are installing our new Samsung dishwasher and there is a slow leak where the elbow and inlet valve connect. We have tried a couple of times, used teflon tape and still a very slow drip. What to do?
Home Depot and other stores have dishwasher installation kits. Don't go to a hardware store this time, go to a store that sells dishwashers-- and other appliance installation kits. There should be braided hoses and all sorts of fun connectors and gadgets to get you going safely. You may need a new inlet elbow for the inlet valve if you have a bad seal because you're replacing an old dishwasher. Speak with a store representative and explain your situation and ask for guidance on install kits.
Jan 31, 2015 | Samsung Dishwashers
Water line attachment
better to safe then sorry . pull out the unit and connect correctly. you dont want to think about it may leak because if leaks it could flood. if i have helped in any way please give me a 4 thumbs up post thanks
Feb 28, 2010 | Dishwashers
I want to buy a new GE diswasher but I do not know about water inlet, is it hot water or it could be normal?
Dishwashers are usually connected to the hot water line under your kitchen sink. Although, a dishwasher has a heating element of its own, connecting it to the hot water side minimizes the amount of time the heating element cycles on and reduces the amount of electricity consumed.
Feb 24, 2010 | Dishwashers
Dishwasher LDF7920ST. Connection to water inlet leaks
if it just started the water inlet is probably defective. this can be obtained at your local hdwre. store. be carefull these oarta are brass and are really soft. pull the dish washer out and tip it up or remove it, dont try to change it where it is.
Jan 02, 2010 | Dishwashers
DISHWASHER WON'T DRAIN WATER
This needs to be investigate properly. Let me provide you with all the steps you need to follow ;-
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I need to get a new pcv elbow connector for 95 chevy beretta v6
I have taken a spark plug boot of of a 90 degree boot of the wire and use this it works so check the junk yard for a plug wire with a 90 degree boot on it and pull it off the wire :)
Sep 29, 2009 | 1995 Chevrolet Beretta
Hookup at water supply
I do believe so.  Check your installation guide for more info.  If you purchased a water line designed for dishwashers, it should have the 90º elbow included.
Apr 02, 2008 | LG LDF8812 Stainless Steel Built-in...
Dishwasher
Low water level. Either the inlet valve has trash in the filter screen or you have a bad valve. To check/replace you valve... turn the HOT water off underneath your kitchen sink. Then remove the kick plate and look under there. You'll see where the water line hooks up to the valve, remove the water line (probably a copper tube, but may be flexible stainless steel). Then remove the 2 screws that hold the valve to the frame and let it drop down. Remove the wire harness off the valve. Then use needlenose pliers... see that rubber tube that's connected to the valve? Squeeze that clamp and slid it back, then remove that tube. Now the valve is out. Now that you have it in your hand, look where the supply water comes into the valve... that 90 degree 3/8" fitting. There are 4 screws holding it to the valve. Before you remove them, TAKE NOTE THE DIRECTION OF THE FITTING. Now remove the screws and lift that section off. There you will see the filter screen. If it's clogged, it won't allow water through. Pop it outta there with a knife tip, clean it thoroughly and reinstall it. Rebuild the machine and turn the water back on. Check for leaks! Job time= ~1 hour
Jul 31, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
625 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
