Need replacement crankcase for Echo CS-750EVL chainsaw
CS 750 EVL rear bar stud pulled out and case is cracked between the two bar studs. Rear stud had been fixed once before. Repair man says I need a different crankcase. Otherwise the saw is great and complete. Used more for cutting ice fishing holes than for trees! Thanks
I don't quite understand the question but, If you are trying to remove the bar on your saw, First it should have come with a tool that looks like a screw driver on one end and, a wrench on the other end. Now!! turn the saw on its side with the Two Bolts facing you. You use the tool to loosen the bolts , just loosen !! next use the screwdriver end to turn the little screw inside the small hole just down from the bolts OK? Turn the screw , which loosen's the chain. Now take the bolts off and put them somewhere SAFE so you can find them when ready to put back on. Pull the plastic cover off , chain off, NOW YOU CAN REMOVE the BAR . I hope this is what you need.
use some channel locks and grip the studs below the threads and unscrew besure not to get the wrench or pliers on the threads as they will get damaged. install in reverse and use some loctite on the threads into the chainsaw so they dont rattle out I just replaced one on my cs400 and have before on my cs 3000
if this is the plastic crankcase machine, the bar bolts are pressed into the case, start by removing the muffler, use a punch and drive the broken stud back through the case, it will have a square head on the rear, re fit the new stud, use a spscer and the bar nut to pull the new bolt fully back through.
