Question about Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input
Audio & Video Connection From SONY HDD Camera To Pinnacle AV/DV card
Sony HDD Sokets & Pinnacle 1394 Cables are not matching.
How do iI connect Audeo Video of my camera to pinnacle card
  • 2,794 Answers
What model Pinnacle are you using?
Posted on Jun 09, 2008
How to use pinnacle 14 studio with sony cam tvr-318
You will need to have an i-Link cable, also known as a IEEE 1394 cable, which is a four pin to four pin cable. That will hooked to the DV output from your camera to the DV input on your computer, if so equipped. Also there is a cable with a four pin i-Link to USB cable which I use my self on my system to import DV from my camera to the edit program.
Hope that this is helpful to you.
Nov 26, 2013 | Sony Handycam CCD-TRV318 Camcorder
Sony CCD-TRV438E Hi-8 Analog Camcorder i need driver to connect with my pc
You need to buy a TV card which comes with audio /video composite sockets. these are female RCA or phono sockets which are also found on your camera.TV cards come with their own software to be able to capture pictures from your Hi 8 Camcorder using the av cables like the ones you use from your DVD to your TV set. There are other cards which carry the av sockets and come with video capture software. These cards are usually PCI cards which are fitted into your PCI slot in your PC motherboard. One other software that comes with such a card is Pinnacle Studio. Its called the Pinnacle AV/DV pci capture card. The one I use is just a DC 10 which works with Studios version 8. Please try any of these cards for your video capture
Oct 28, 2011 | Sony CCD-TRV438E Hi-8 Analog Camcorder
I purchased a Pinnacle Dazzle to connect my Sony DCR-HC38 to my computer. I do not know how to connect the camcorder to the Dazzle device.
Sony DCR-HC38E should have an interface called 1394, or the firewire. so you need to use a FireWire cable to connect it to your computer's firewire interface, some laptops have it built-in, If you don't have one on your computer, you can either purchase a IEEE1394/FireWire adapter, which should be under 100 or even $50.
Connector Type1.0 x Composite video/audio output , 1.0 x S-Video output , 1.0 x USB , IEEE 1394 (FireWire/i.LINK)
Sep 09, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
Good Day! How will i connect and manage my camera to computer.
For the DCR PC101E you need to use a firewire cable or 1394 cable or the i-Link cable which goes to your computer this is one and the same thing with different names. However if your computer does not have a connection for this you must go and buy a 1394 pci card that you have to connect inside your computer. These usually come with the software drivers for the 1394 card.
Mar 16, 2011 | Sony Handycam DCR-PC101E Mini DV Digital...
While capturing video from sony DCR-HC 40E via pinnacle 14 HD through IEEE 1394 in wondows 7, the captured video showed too many frame drops.
Sounds like time code breaks.
If you stripe the tape (record in one continuous run with the lens cap on and audio off) this will assist greatly.
Feb 17, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
I have a sony handycam dcr-hc19e. I am trying to transfer to my laptop which only has a usb connector and i have updated software still wont work - any ideas?
If you computer has Windows Vista or Windows 7 installed, then streaming over USB is not supported on those operating systems.
It is only supported on Windows XP.
At any rate, the quality of the video when streamed over USB is of considerably lower quality when compared to the video when transferred of IEEE 1394 connection.
If you don't have Windows XP, you'll have to find a computer with an IEEE 1394 connector and buy a Sony DV to IEEE 1394 cable. The DV port on the camera is right next to the USB port. Consult your local Sony retailer to find the proper cable for your camera.
Dec 30, 2010 | Sony DCR-HC19E Mini DV Digital Camcorder
I need a MovieBox DV (1394)driver compatible with
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
Jun 25, 2010 | Pinnacle Studio MovieBox DV 9 (210100349)...
Copying home made video from sony Hi8 tapes to Sony DV mini tapes
Sony DCR-HC21 has a multi-AV in, your Hi-8 should have a mini (4 band) to multi AV out. The cable would look like a stereo headphone cable on one end with thre RDA type plugs on the other end; red, white, yellow. The mulit in on the DV would probabaly be the same type connector. Youd have to use a coupler set for the two multi-av cables to bridge video to video and audio to audio. Come out of the Hi8 into the miniDV recorder. You should not need a Dazzle unless you want to transfer to a PC for editing before moving video back to a miniDV tape.
Jul 26, 2009 | Sony DSR-30 Mini DV VCR
Connecting a Sony Camcorder to a Compaq Presario
Didn't actually find a solution. Looked at another HP notebook I have and found it has a 1394a port so I'll change computers.
Nov 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
DV Camera problem
Are you trrying to record from commercial media or home produced video sources? Sounds like copy guard is being invoked....accordianman
Jul 10, 2007 | TruTech TT1620 DVD Recorder
Pinnacle Systems Studio AV/DV Version 9 Deluxe (202261744) Audio Input Logo
153 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
