i had this with my 2.0 IDE laguna. it was due to a low voltage level on battery enough power to fire the relays, but not enough to turn the starter. check that your battery voltage is high . i ended up getting anew battery and a battery conditioner from ebay to just keep the voltage topped up when not using the car, i never found what was causing the drain on battery though
Hi, I have the same problem , tries to fire up but doesnt seem to get enough power and cuts back to off. Ihave been told its a capacitor that is failing...These are very cheap to buy but its a daunting thought to change it myself
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again. But if otherwise, tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Its all relative. With most of these compact cameras, to conserve power, the camera does not always keep the flash ready to fire at any given second. Firing the flash uses a lot of juice, so if it was always at the ready, the battery life would be reduced to half or less, which would would cause more problems.
When you press the button the camera then tries to cycle up enough flash power that it thinks it will need to light the scene correctly. This will require less time if its in the day and longer if its dark.
Add more time if the battery life is low.
Once you fire the flash and exhaust all the reserve power from the buffer, the camera will need to recycle itself to garner enough power for another flash, this again adds time.
More expensive cameras have better power management and can cycle up faster.
