Question about Refrigerators
Fridge freezer temprature/hot doors
Both fridge and freezer doors are hot , temprature up and down from -8 to -22,Any idea whats wrong ? thanks
  • Gary Davd
    Gary Davd May 11, 2010
    plz post the model # from your unit so we can help
    President:
  • 1,314 Answers
If your talking about the post between the doors its supposed to be hot its to keep the gaskets dry but you can clean the coils on the fridge if you haven't for awhile that will help keep them the right temp as far as setting the temps i always using your milk and ice cream every one knows how they like their milk and you don't want to have to dig your ice cream out with a chisel
Posted on Feb 16, 2008
My fridge temprature constantly keeps going up even after turning on the supper.
Something new is blocking the airway from the freezer to the fridge. Check the freezer, look for vents that have been blocked. If it has been blocked too long, ice can build up in passageways in the freezer that are hard to get to. Maybe the fan got jammed, you should hear it when the freezer door is closed. It usually stops when the freezer door is open, but if you push the switch it should run.
Nov 21, 2013 | Refrigerators
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
I have a dometic rm2820 up right fridge on bottom freezer on top. the freezer gets really cold but the fridge part stays warm.
Did you by chance recieve a recall from the manufacturer .? we got one about two years ago we had the same problem, they fixed it because there was danger of fire, i would contact them
Jan 19, 2012 | Dometic Refrigerators
Fridge part is not cooling well
You have a blockage in the system. Need a technician to come and replace the drier and regas system. Will run correctly after that.
Sep 18, 2009 | Whirlpool ET1FHTXM Top Freezer...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Profile Side by Side is getting too cold on the fridge side.
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
I have a Maytag 500ltr fridge freezer model GT1727.The evaporative area behind the rear cover in the freezer compartment freezes solid also the freezer door has ice inside it which then drips water,in turn...
The problem is the ice inside it is clogging the Fridge and it is causing the temperatures to be wrong
take everything out of it unplug it and use a hairdryer to melt off every bit of ice inside and behind the back wall.
Jan 11, 2018 | Refrigerators
Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Aug 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
I have a Samsung SR-S2028CSS side by side Fridge Freezer with an icemaker water dispenser. The freezer is run at -23 degrees and the fridge at 2 degrees. Recently the ice, having been made in the icemaker,...
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Apr 08, 2008 | Refrigerators
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
