Question about DISH Network IR Remote Control
About IR REMOTE CONTROL
We wanna know about working principle of circuit diagram of IR REMOTE CONTROL reply us fast
  • 51 Answers
Are you referring to the circuit board itself?
Posted on Aug 29, 2008
Remote receiver will not work
Go online to Sony, contact customer support and the technical department for a circuit diagram so the correct number for the ir receiver can be extracted.
Apr 23, 2012 | Sony MHC-EC98Pi Shelf System
I want to know the simple example circuit diagram of a remote control
There is no much on diagram but a networking to matrix the inputs of different source to a SUB- PROCESSOR which is the heart of the unit. This outputs IR to the IR LED's to be emitted.
Please check for tips to repair a remote:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Jun 14, 2011 | Televison & Video
Need tv code for an 1.5 ir remote for dish network
You can find your remote control manual on the link below:
http://www.dishnetwork.com/supportsection/manuals
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 29, 2011 | DISH Network IR Remote Control
My Sony Bravia doesnt work with remote control, with any remote including universals
You didn't include the Sony Bravia model that you own - so I can't be more specific. If the TV is set up to use RF (radio frequency) codes instead of IR (infrared) codes; the universal types probably will not work. This is because most universal remotes are the IR type.
The remote included with your TV may have inadvertently be switched to send the codes as an IR type while the TV will respond only to RF type codes. It may also be that the TV was changed to respond to RF codes only. Either way, check your manual (or your TV menu settings) to see how to set the TV and the remote to work in the same mode.
If you can't find your manual, reply with your TV's model number - and if possible the remote's model number, too. I'll see what I can find that is specific to your TV.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 06, 2011 | Televison & Video
I have a 3.2 IR dish network remote. How do I fast forward through commercials on DVR?
you can only fast forward recorded movies. Use the dvr button with the arroww that points to the right.
Feb 26, 2011 | DISH Network IR Remote Control
I have a floor fan and the remote isn't working.
check IR receiver on the fan circuit board, resolder the lead.
Jun 19, 2009 | Holmes Products Holmes HT35R-U Tower Fan...
Harmony One remote won't input channels very well
Most DirecTV receivers are able to be controlled with IR (infrared) or RF (Radio Frequency) signals. DirecTV receivers are usually set to be controlled by RF.
To control a DirecTV PVR / Satellite, it needs to be set to respond to an IR Remote:
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
Note: Some models of DirecTV may have different steps to enable IR. You may need to refer to your user manual
Harmony Remotes only control IR signals. so this is not the issue. The Harmony Remote should control the tv. the original remotr needs to be tested for IR or RF.
The device we are working on that is not being controlled by the Harmony Remote could be operating on RF (Radio Frequency) signals. Harmony Remote can only control the devices that operate on IR (Infrared) signals. Most devices that work on RF signals can be changed to operate on IR signals, and this usually could be done by changing the remote control command mode to IR from RF.
Please follow the steps listed below to test to see if the device is being operated on RF or IR signal:
1- We need to use the original remote for that device to complete this task
2- Using your hand or a thick and wide object (wall, pillow, book...), cover the top part of the original remote. In other words block the direct positioning between the original remote and the device.
3- After you cover the top part of the original remote (or used an alternate way to block the direct communication of the original remote and the device), try pressing the buttons on the original remote to see if it can still send commands that can be received by the original remote. You can try powering on/off your device using the original remote when the original remote is being blocked by your hand or another object.
4- If you still can control the device using the original remote without a point of sight, your device is being operated on RF signals. If you cannot control the device without a point of sight, then it is IR operated.
5- If the device is RF operated, please change the command receiving mode to IR rather than RF and test the Harmony Remote.
6- If the device is IR operated, please contact us again by replying to this email and let us know if none of the commands or some certain commands are not working for that device.
You can usually find the information on how to switch the device to be operated on IR signals rather than RF signals, through the user manual for your device, or by contacting technical support of the manufacturer for that device, or even sometimes reaching the information simply by doing a basic research over the internet.
Mar 31, 2009 | Logitech Harmony One LCD Touchscreen...
My one for all won't program...
dish network remotes are universal, you can program your receiver, vcr/dvd, telivision and stereo to most remotes. if you need info on this just post again, otherwise i would list your issue under the remote brand
Jun 24, 2008 | DISH Network IR Remote Control
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
Dvd will not play
Hi there. If i understand correctly, you do have the official microsoft DVD dongle and remote ? If so, you might wanna see if the remote is defective. Do you have a camcorder at home ? There is a trick to see if a remote sends it's infrared signals. Put the camcorder on, in a dark room, and put the IR transmitter on the top of the remote in front of the camera. You'll see the IR remote transmitter blinking if you press some buttons. Human eyes can't see it, but the camera does! Try it with another remote that you're sure that works, you'll see. If the microsoft xbox remote doesn't do anything, check batteries, else it's proably defect. If you like to tinker a bit with things, you might wanna open it up to check if there's any cold solder point on it (a broken connection), but you need soldering skills to do so. Else, you'll need a new remote. Hope that helps ! cheebster.
Jul 03, 2007 | Microsoft Xbox Console
DISH Network IR Remote Control Logo
120 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
