Question about Biostar computers10: Main Board MB-5800TUC-A with AMD CPU (TC80016) Motherboard
Will these work together?
MB is a: M7VKB Socket A ATX form factor VIA VT8363A chipset
CPU is a: AMD Duron DHD1300AMT1B Socket A (socket462)
I have all spec if you need more info!
  • 55 Answers
Looks like a match to me. Except for the very highest end processors in the socket A line, all socket A processors should work in any socket A mainboard.
Posted on Feb 16, 2008
What is the fastest cpu I can put in my GA-7IXE4? PS: I presently have an 800 MHZ cpu installed. Thank You in advance.
Anything upto an AMD K7 Sempron 3000+ and will also take upto 768 Mb of sdram memory ....cheers from Scott
Sep 05, 2011 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
I HAVE MY PROBLEM REGARDING MY MOTHERBOARD, AMD ATHLON EP-8KTA3L
Specification DFI AK74-SC Model DFI AK74-SC Socket Socket A Motherboard CPU AMD Athlon /Duron processor 600MHz-1.2GHz and faster Chipset VIA KT133/686A Memory 3 DIMM sockets
max. 1.5GB (unbuffered or registered)
Supports PC 133/ VCM SDRAM BIOS Award / 2Mbit Power Management ACPI and OS direct power management
Wake-on event: RTC/Modem/LAN Hardware Monitor System and processor temperature Expansion Slots 1 AGP slot (Supports 4x/2x AGP)
4 PCI slots
1 AMR slot
1 ISA/PCI slot Audio AC`97 Audio codec with Yamaha AP Super I/O 2 x NS16C550A compatible UARTs
1 x SPP/ECP/EPP parallel port IDE Dual PIO mode 3/4 EIDE channels up to 4 IDE devices
Ultra DMA/66 transfer rate up to 66MB/sec Rear Panel I/O Ports 2 x USB, 2 x DB-9, 1x DB-25, 1x PS/2 Mouse,
1 x PS/2 Keyboard, 1 x game/MIDI, 3 audio jacks I/O Connectors 1 x IrDA, 2 x external USB, 2 x IDE, 1x Floppy,
1 x ATX power, 3 x fan, 1 x WOR, 1 x WOL, 3 x internal audio Form Factor 4 layers ATX Motherboard Form Factor
30.5 cm x 22 cm 12.0 inch. x 8.66 inch. Warranty DFI AK74-SC Motherboard Pro DOA Warranty ONLY
DOA DFI Warranty
DFI Warranty
motherboard
If you want more Information then go to this link :-
http://www.motherboardpro.com/Motherboard-With-ISA-Slot-DFI-AK74-SC-1-ISA-4-PCI-AGP-Socket-A-ATX-Used-Motherboard-p-39.html
Dec 03, 2008 | DFI AK74-SC Motherboard
Trying 2 figure out what type of memory 2 use?
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor
Socket 462 with FSB 200/266MHz
2 DDR266/200 Memory Sockets
6channel AC 97 Audio
2 ATA133 Channels, up to 4 ATA 133 IDE Devices
6 USB 2.0/1.1 Ports (4 ports by optional cable)
Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 )
South Bridge: VIA VT8235
I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets
DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only)
3 x PCI slots (PCI 2.2 compliant)
1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector
2 x USB 2.0/1.1 header (4 ports USB cable optional)
1 x CD_IN header
1 x COM (serial) port header (Optional COM cable)
1 x S/PDIF in/out header (S/PDIF in/out cable optional)
1 x CPU fan header with fan rotation detection function
1x System fan headers with fan rotation detection function
2 x 5 pin system panel header (Intel spec)
1 x Front audio header (Intel spec)
1 x IrDA header
1 x Case Open detection header
1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM
Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Special Feature
Certifications
FCC, CE, BSMI,WHQL
Form Factor
Micro-ATX (218mm x 244mm)
Jul 11, 2008 | Intel Motherboard
Motherboard crashed
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Mar 15, 2008 | Intel Motherboard
MPN: A7S333
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
BIOS Type: Award
amd 3200 + anthlon ok with fsb 266 mhz soket a
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Computers & Internet Logo
78 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
