Question about RCA F36665 36" TV
TV turns on and off by itself
My television will turn on and off by itself. When plugged in the unit may go a week at times and be fine then all the sudden it will begin turning itself off and on. I have taken the unit apart and cleaned it and still the same issue.
  • Anonymous Oct 28, 2008
    tv turned on and off by itself for almost a year then quit responding to manual buttons or remote altogether. now it won't turn on at all.
  • Try replacing the batteries in your remote.
  • Cover the infra-red receptor in front of your TV to see if you’re getting unwanted signals from the receptor; covering the receptor with a bit of foil should do the trick.
  • Have you recently added equipment that might interfere with your TV’s operation—like a remote control extender or a new device for your audio-video system? Remove these devices and test the TV.
  • Posted on Sep 06, 2008
    TV will not power off and volume now does not work - volume stuck on current setting
    My TV done this one week ago. I unplugged it for 10 seconds and then plugged it back in. Turned it on and it worked fine. Guess it reset itself.
    Jan 20, 2011 | LG 42LC2D 42 in. LCD HDTV
    I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
    It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
    Aug 26, 2010 | RCA 27R410T 27" TV
    TV turns itself off.
    Check for a loose wall outlet. try plugging it somwhere else. that happens to me many times. it is not your tv.
    Aug 04, 2009 | Televison & Video
    No pic
    alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
    May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
    Goodmans 282NS-T
    SNAP! got the same problem too. it's soooooo annoying. i think we should have a TV bonfire!!
    Apr 07, 2008 | Goodmans 217NS TV
    Turns off
    Check the software and if it is not EJ30U_0.101.0.0 go to www.usasupport.com and put the firmware onto a USB stick. It will give you all the instruction on how to do it. If the set still turns off the problem is the SSB. Contact Philips @1-888-744-5477 and have your receipt to make sure the unit is under warranty and they will have a tech come out and fix the set.
    Apr 06, 2008 | Philips 42PFL5332D 42 in. LCD Television
    Mitsubishi Big Screen VS-45607
    probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
    Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
    Tv keeps turning itself off
    you must contact service bycouse you need the asistance
    May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
    RCA F36665 36" TV Logo
    85 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
