Next, press [STAT] [5]:SetUpEditor and, the SetUpEditor command will display at the Home screen for you. It is important to do this process before you start creating lists to be analyzed and, used on the calculator. This will save you a lot of hardships from data that is already being used and, in the calculator registers. You can also associate your list to your project so, that other data won't conflict and, cause errors.
You also should add the rest of the lists or, structure of the CubicReg(L1,L2,Frequency list,RegEQ). The SetUpEditor is a great tool to help you gain the proper structure. The default for frequency is sat at 1 if not used but, having a RegEQ (such as Y1), will help the calculator to calculate your data. Just remember to set the mode to Func before you use the SetUpEditor.
If you have any questions, just post a comment and, I'll respond quickly.
