Question about Gaggia Carezza Espresso Machine
Gaggia Carezza not turning on
I have a Gaggia Carezza espresso machine which I've used regularly for the last 2 years without any problem. This morning however, I tried to make a cup of coffee, but the light is not coming on. I tried another electrical outlet, thinking maybe something was wrong with the usual one, but still nothing. There's nothing in the manual about this. Anybody have any advice? Thanks.
  • Anonymous May 06, 2008
    Same problem. Two years of use, this morning no green light. Dead. How did you fix yours?
I just bought a broken Carezza for my office (and hacking)-- the owner said the power switch only worked when he held it down hard.
Taking it apart, the main power switch-- a DPDT automotive-style unit-- is broken on one pole-- the wire connectors are slightly melted and darkened, and the switch has melted, discolored plastic around the metal tabs.
A new switch should bring it back to life, and I'll install a removable power cord and 15A fuse for niceness/safety-- the switch is rated for 20A at 125VAC so shouldn't have fried.
Posted on Sep 07, 2008
  • 2,039 Answers
Lots of time we always think the worst our trouble is probably the plug that goes in the in the wall get a strong plug at the hardware store cut the wire and install plug its a cheap fix to be sure before cutting thr wire you would had to remove the cover and look if the power goes in the machine lot of work our choise
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 17, 2008
Replacement for Gaggia Carezza ON switch?
It is a standard switch, so you can repalce it, as long as you know what you are doing
Aug 19, 2012 | Gaggia Carezza Espresso Machine
Water is leaking around the edges of the basket and into the shots. Is this an o-ring gasket or a group gasket issue?
Group gasket issue, depending on the age of the machine the gasket might be dirty, use a Q-tip or your group brush to clean, if machine has over 2 years use then replace group gasket.
Sep 02, 2010 | Gaggia Carezza Espresso Machine
I have a Gaggia Carezza machine that is about 3 years old. Yesterday, the power switch seemed to have some resistance when I turned it off. I also smelled a burning plastic smell. Today, the switch seemed...
The description sounds like the switch has failed due to it's internal contacts arcing. I have a like problem with Mary214 that is ongoing. Please follow that thread to find your fix.
Dec 27, 2009 | Gaggia Carezza Espresso Machine
Cannot find replacement for the Gaggia Carezza powerswitch anywhere. Model discontinued. Want to jump the wires so that it is on when I plug it in.
Here is a list of gaggia dealers, one of them might have it, if not check with radioshak.
I do not have it so you can skip me.
Oct 09, 2009 | Gaggia Carezza Espresso Machine
Cannot remove shower holding plate
After removing the 2 allen wrench bolts in the holding plate, place the flathead screwdriver on the plate and using side of group as leverage lift. Check diagram below92b399a.jpg
May 27, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza will not turn on
look on top of the boiler you will find a microthermo  it trips when the machine gets too hot and you are going to have the replace it. now i posted the fix in a form for the same thing. and where to get one.
Apr 20, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine burned out
as i understand from your decriptition, you had temperatire rising in extreme point. termofuse should worked but it didnt, i advice you to change all 3 and some seals:
  1. Thermofuse
  2. Thermostat water L=107C
  3. Thermostat steam L=145C
  4. Gaggia gasket 6-pc. Kit (during changing them you can clean boiler too)
here is the link for diagram:
http://www.partsguru.com/user/Carezza%20diagram%20and%20parts%20list.pdf
here is the link for parts:
http://www.partsguru.com/GaggiaCarezzaespresso.html
Apr 03, 2009 | Gaggia Carezza Espresso Machine
Gaggia Carezza doesn't brew
May need priming -- follow the directions in the manual.
Jul 01, 2007 | Gaggia Carezza Espresso Machine
Gaggia Carezza Espresso Machine Logo
202 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
