The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Hello Roy Gaudette - If you only have an issue with one burner lighting, then you might have a clogged valve. This is not something you should clean on your own if you have never done this before. I would contact a professional or your manufacturer first. You could also have a blocked or bad valve which would require a full repair service call.
