Question about Kenmore 53301 Dehumidifier
No water in bucket
We just bought this new dehumidifier after leaks came into house due to ice damming. Have been running it for 2 days and thus far not a drop of water has appeared in the bucket. Is this because it's winter and too dry? Or did we buy a bum unit? Is there any way to test the dehumidifier other than simply running it normally? We put a bowl of water and a wet towel near the unit--still, no water has appeared in the bucket and the wet towel is still a little damp after 24 hours. Thank you!
  • 883 Answers
Possible that the cooling fins have frosted over...this happens when a cold surface appears in a humid room that does not have enough heat to prevent the freeze-up on the fins. If you look at the fins (above the water bucket), you may see the frost. One solution is to turn up heat in room, followed by placing a fan to blow air through fins if still frosted. If you do not have a frost problem, then ensure compressor is running. If comp is running, then return dead unit.
Posted on Feb 16, 2008
Why does Frigidaire dehumidifier LAD704DUL has ice on the coils?
Hello Friend, thank you for your question!
I see that you have frost accumulating on the coils of your Frigidaire dehumidifier, LAD704DUL. Typically frost appears on coils either because your dehumidifier has been turned on recently or the room temperature is too low. Sometimes this is normal due to refrigerant rushing through the coils and usually it disappears within 60 minutes. However, if your dehumidifier is not removing moisture, then at this point your dehumidifier may possibly been experiencing a sealed system issue. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Hope this helps! - Z
May 15, 2014 | Frigidaire Dehumidifiers
My Maytag dehumidifier runs but does not collect water in the tray. Instead, it appears to leak from the bottom and ice formed near one of the side portions. Please let me know what you think is the...
This one has a leak in the refrigerant system... it will need to be found, fixed, and recharged...which will cost more then a new one...in most cases.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 13, 2011 | Maytag Dehumidifiers
It ran for a couple days, went to empty the bucket and maybe a inch of water was in it. normally i'm empting it everyday. when i took the bucket out i noticed a little ice under the machine.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
May 07, 2011 | Fedders A7DH45B2A Dehumidifier
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
I have the dehumidifier in the basement and turn it on; it ran for a day and no water collected in the lower bucket. Am I doing something wrong? I would think it would pick up some moisture in the...
heatman101
Jul 01, 2010 | Whirlpool AD25BSR Dehumidifier
Dehumidifier not dehumidifying
heatman101 ....
May 25, 2010 | Whirlpool AD50USS Dehumidifier
I just bought this and it keeps leaking, why?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 01, 2010 | Sunbeam Warm Mist Humidifier Dehumidifier
Unit works fan runs lights turn on but no water in the bucket,
Some units use the condensate water to cool down the condenser coil. This is why no water is present. If water is leaking from the unit or you are still sceptical about this problem, I would call for service.
Mat
Jul 16, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Won't collect water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Mar 11, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier runs, but bucket has very little water in it.
heatman101
Aug 14, 2008 | Kenmore 53301 Dehumidifier
Kenmore 53301 Dehumidifier Logo
272 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
