DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Polaroid DRA-01601A will not power up
By garytn9988 on Feb 16, 2008
I have an almost new Polaroid DVR model DRA-01601A. Yesterday it worked fine the next day it wont even power up. I hear the fan turning in the back when connected to the outlet but it does not turn on.
Same Problem
Feb 22, 2009
-   Fan turns on but won't power on, not even LED light or display. -   shawn1010
Dec 02, 2008
-   wont power up anymore. Piece of junk. -   Guest
Oct 26, 2008
-   My Ploaroid DRA01601A will not power up. It locked up to where I could not get it to do anything. I pulled the power cord out of the plug for a few seconds, plugged it back in and nothing happened. Does anyone have a solution to fix? -   blackhawk324
Aug 20, 2008
-   Got a power light but no display. Won't power up. Worked fine the day before.-   wardj
Aug 14, 2008
-   Our unit also acts erratically - sometimes needs to have power removed for 30 sec to reset the unit. HD channel labels also add 30 to actual value. Sometimes HD tuner locks to only one channel although label changes between stations. Have to remove power to reset this also.-   gummy2
Best Solution
posted on Jun 05, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
these units are famous for capasitors popping in the power supplies.
Solution #2
posted on Nov 10, 2008
Very Helpful)
viki_3578
Rank: Apprentice
Rating: 100%, 5 votes
99.9 % of the times its the capacitor which is blown. I had spent few weeks to investigate on this and ultimately found this solution. Till date I have replace two capacitors. To determine which capacitor is gone, Check on the flat silver surface of capacitor. If its not 100% flat it means its gone and you need replacement. Pl. check my attached file to understand on details of inside configuration.
Hopefully it works for you.
I am not able to upload pdf which I have created. Pl. contact me via email to get pdf file
viki_3578@yahoo.com
Regards,
viki_3578
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #3
posted on Nov 11, 2008
Helpful)
gummy2
Rank: Apprentice
Rating: 88%, 2 votes
We found that our problem may have been heat related (the unit might have been overheating) We reported our issue to Polaroid and they were very willing to replace the unit (as long as we paid for shipping the unit back, of course) However, after reporting the problem and setting up the exchange, we spent some time burning our videos to DVD prior to returning the unit, during which we increased airflow to the unit. During this time we experienced almost no failures, leading us to believe that it may be a thermal issue. In the end, we're using our new unit from Polaroid, so far with no problems.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Sep 12, 2009
Not Rated)
davidiode
Rank: Apprentice
Rating: 0%, 0 votes
Mine have severe problems, I removed the front panel and front board and replugged in all the connectors, and when put back together it worked. I think I had a shorted trace on the front panel to one of the screws (or maybe the force was just with me) anyway thats my story
Was this helpful?
Yes
No
Solution #5
posted on Feb 17, 2008
Not Rated)
garytn9988
Rank: Apprentice
Rating: 0%, 0 votes
I believe I found the problem but just will not be able to fix it unless I can find a new main board cheap. It would appear power is getting to the main board but will not power up.
Thanks anyway
Was this helpful?
Yes
No
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
''how do I change the settings on my Magnovox MOdel E8C60UD DVD player for multi region''
Answer
how do i get ride of 2 screens on 1 tv screen?
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 23, 2008
My unit's fan works, but will not power up as well
Comment by Guest, posted on May 19, 2008
Bought new TESTED and WORKING from ebay seller, but it show this exact symtom when I plugged it in. IE NOT tested enough!!!!
Comment by camaro1979, posted on May 06, 2008
same problem exactly happened to my dvr i contacted polarion by email and now im waiting
Comment by Guest, posted on Apr 26, 2008
same power problem but on a Polaroid15" LCD TV/DVD combo
Comment by rwmcm, posted on Apr 13, 2008
I am having exactly the same issue. The player is barely 4 months old.
Describe your DVD Players problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
