Question about Panasonic Lumix DMC-FX01 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
Help! I took some precious pics and I cannot retrieve them because of this error.
I tried to use my card reader but it was not compatible with the SDHC card.
Do you think my pics were deleted somehow? What do you suggest I do?
I just bought a new camera - Panasonic Lumix DMC - TZ3 and separately bought a 4GB SDHC memory card. When I put the card into the camera it says Memory Card Error; Memory Card Parameter Error.
Is there anything I can do? Or is this a dodgy card? I haven't taken any photos yet.
My camera has been functioning fine with a 1.0BG SD card until yesterday it suddently said "Memory Card Error - Memory Card Parameter Error". I tried using a card reader but it doesn't work, cand I can't take anymore photos with my camera. Are all the files on my card now lost?
  • 8 more comments
  • Anonymous Feb 17, 2008
    tried to download the pics and am unable to do so
  • nhp16 Feb 19, 2008
    I have a Panasonic FZ18 and have suffered the same problem and the same error message.
    The new 4Gb SDHC works in my computer (Windows XP) using the supplied USB 2 card reader. No problems reading and writing files.
    I have tried re-formatting the card for use in the camera using Panasonic program downloaded via the link from the customer support site at http:\\panasonic.co.jp/pavc/global/cs.
    This did NOT resolve the problem. Still get same error message, and the card still works via USB.
    Any solutions gratefully accepted. Perhaps the card is dodgy. My past experience with Panasonic cameras is that he camera itself is unlikely to be at foult.
  • T R A C Y Aug 04, 2008
    I also took some very memorable pictures of vacation and accidentally dropped my camera. Now when the memory card is in the camera, it will not work and I had hoped to retreive them with the card reader. Needless to say, I got the same message...ERROR ON CARD. Please Help!!!
  • nlrms Aug 17, 2008
    Help- Our entire two week vacation is on a 4gb Kingston SCHC card, which I bought along with a new Panasonic DMC-FS 3 camera just before the trip. I was unfamiliar with the HC format, but was told by the salesperson the Panasonic required the HC card. It worked fine during the trip. After the trip, I inserted the HC card into the card reader I have used for my SD cards and it did not read. I then reinserted the SCHC card into the camera and now I have a card error message and I cannot access the pictures at all, even through the camera. I am very worried. Advice is very much appreciated.
  • stephx Aug 21, 2008
    I had exactly the same issue using Panasonic FS 3 + 4GB Kingston SD HC.
    After 10 days taking pictures, I can't read it anymore using my camera, PC SD slot, USB dongle.
    I don't know what else to do and I want to get back my holiday pictures!
    Thanks in advance for any tip
    Stephane
  • enrico1222 Sep 23, 2008
    I have bought a Samsung NV24 and very delighted...until came the moment to read the SDHC4 mb in my XP based computer.
    No problem in reading the same card under Vista environment.
    Any suggestion to solve this problems?
    Regards and thank a lot for help given.
  • monika partridge Oct 02, 2013
    The sd card is too large.
  • Anonymous Mar 12, 2014
    can't see photos when my memory card is in camera - memory card error - memory card locked
  • Anonymous Mar 18, 2014
    What kind of SD card should I use for this camera?!? Used to use the Mini SD tapes - but now I want to use SD card- tried to use my SDHC card & it read card error
  • 3 Answers
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Posted on May 21, 2008
I think your camera is not compatible with the SDHC card you bought. Check this: http://panasonic.jp/support/global/cs/sd/connect/dsc/dsc.html
Posted on Mar 03, 2008
Sometimes, there are simply certain brands of cards, that are not compatible with certain brands of hardware, i.e. cameras or card readers. I have that problem with the built-in card-reader on 2 of my Toshiba satellite laptops, and 2 out of my 3, 2GB SD cards. Try a different brand of HCSD card, perhaps search for a list of compatible card brands, or checking the with card's manufacturer before purchasing.
Posted on Apr 10, 2008
The link refers to Panasonic's tests on Panasonic cards. Hardly surprising that all of them are compatible!.
Why would any SDHC card NOT be compatible with the camera if the card itself is not dodgy?
The manual specifies SDHC cards MUST be used for 4Gb and larger. For 2Gb and les, SD are OK.
My problem is that the 4Gb SDHC card works OK in the computer (and therefore is seemingly OK), but doesn't work in the camera. That is what I can't understand.
4 Suggested Answers
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Posted on Dec 27, 2007
informatica
  • 1114 Answers
Hi - You will need to get an SDHC reader and then try the following procedure.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Sep 10, 2008
actionreplay
  • 73 Answers
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
Posted on Aug 24, 2009
I have a Pentax Kx and recently bought an 8Gb memory card. However I get a lot of blank images with the error message 'image cannot be displayed' especially if I use the continuous shooting mode....
Dear,
First of all you need to confirm that what kind of memory card your are using. The officially recommended type and brands are here
Toshiba *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
Panasonic *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
SanDisk *SD Memory Card - Capacities: 512MB to 2GB *SDHC Memory Card - Capacities: 4GB to 32GB
rather than these might be problematic or not compatible...
Check this first
Best of luck!
Jul 10, 2011 | Pentax Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Cannot get pictures off of SDHC Card 4GB
Could be it only supports SD cards up to 2gb but not SDHC.
Jun 16, 2009 | SanDisk 4GB microSD High Capacity Memory...
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Apr 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Informatica
Sep 10, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
SDHC Memory Card error
I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
-prmolina
Feb 19, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Dec 13, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
You may fix the memory card error and recover your files by follow this memory card recovery guide which helped me last time:
Fix memory card error and recover data from memory card
good luck!
Nov 09, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Error message: card cover open..yeah right
Hmmm, I'm thinkin' if there's no memory card in camera, there are NO memories, aka formerly known as photos. Unless there is some sort of an internal memory, but me thinks not. As for error message, might be because....card fell out while an image was being captured.
Apr 28, 2007 | Olympus FE-130 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
2,733 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
