Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP OJ 7410 printer disappeared
Hi guys, back again. Last prob solved but slightly diff prob this time. Currently using Vista with ad-hoc connection to HP OJ 7410 printer. For no apparent reason the silly printer just stopped working and disappeared frm my list of printers.
I am restricted frm scanning and printing as my laptop says that the printer doesn't exist. Tried adding a printer to set the HP OJ 7410 as default printer via w/less connection but no good.
When using the 'setup' config button on the actual printer itself, it picks up the hpsetup connection and successfully connects. My laptop aims to differ though.
I'm a bit of a coconut and am really confused :-\ .
Was wondering if any suggestions other than reinstalling could be offered so as to avoid the lengthy hassles of downloading drivers etc for Vista.
Many thanks, much appreciated.
  • Nodel Neneiya Feb 17, 2008
    Thanks for trying. I got the printer set as the default again - only this time I'm not able to use my HP Solutions program to scan. I can print normal docs which is good, but keep getting "No HP devices have been detected" message when I try to go into HP Solutions program to scan. It then just automatically closes by itself.
    I tried downloading the drivers/software features from HP website but keep getting message, "File is corrupt" and am unable to d/load and install.
    I honestly don't know what I've done wrong and I think i'm on the verge of putting up the white flag.
    I'll try anything anyone has in mind. Anything.
    Thanks heaps again.
Nothing to worry about. Go to HP.com and from there select Software and Driver Downloads. Download the Full feature software and driver for windows Vista. Run the Installation.
If the softwares are installed it will ask you to "Add a device". Add a device and select network option. The device will be installed. Now there is a patch on HP.com for unexpected uninstallation. Download it and install it on the computer. It will resolved the issue.
Posted on Feb 16, 2008
HP Photosmart c6380 wireless printer works fine, but windows xp does not recognize the scanner
  • First, we need to create the Ad hoc network that will provide wireless connection between your computer and printer. On the right hand portion of the Taskbar, you can right-click the wireless icon and choose "View Available Wireless Networks". Or you can double click the wireless icon, then click "View Wireless Networks". It is also accessible from the Control Panel. Either way, the same window as shown in step 2 will pop-up.
  • 2
  • setup-xp-via-ad-hoc-1.2-120x120.jpg View Wireless Networks The Wireless Network Connection window shows you all the wireless networks in range including the network where you are connected. If you have many neighbors with wireless networks, it will all show up. Click "Change advanced settings" and it will bring up the Wireless Network Connection Properties window. Choose the "Wireless Networks" tab and at the bottom click "Advanced" button.
  • 3 setup-xp-via-ad-hoc-1.3-120x120.jpg Wireless Networks Properties From the Advanced option window, choose "ad hoc" networks only. This is just to simplify the process. You should also bring this back to original setting after you are done connecting via Ad hoc. You may choose to skip this step if you wish and you should still be able to make the connection without a problem.
  • 4 setup-xp-via-ad-hoc-1.4-120x120.jpg Create the ad hoc network Click the "Add" button and type in a name for your Ad hoc network. Make it more intuitive so you can easily recognize your own network just in case there are other Ad hoc in range. Check off the automatic key and enter a 5 or 10 digit network key. This is the same key that you will input at the printer later. Click OK and then OK again. You are now connected to the Ad hoc network. You are half way through.
  • 5 setup-xp-via-ad-hoc-1.5-120x120.jpg ad hoc network Make sure the printer is ON as well as the wireless radio button. On the printer control panel, press the setup button to access the menu. Go to Wireless Menu and press OK. Press the arrow to go to Setup Wizard and press OK so the printer will automatically search for wireless networks in range. From the list of networks, find the SSID or Ad hoc name that you created and press OK and type in the network key using the alphanumeric keypad on the printer. The printer should confirm the connection in less than a minute. That's it! Try to print a test page to make sure everything is working properly.
  • Dec 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
    My HP OfficeJet 7410 is offline and I can't get it back online -- I have checked all connections. This happened after the last Vista update. Also, when it did print, the duplexing didn't work. Help!!!
    Since this happened AFTER a Vista upgrade, I suggest that you look at the printer in the hardware are of Vista.
    1. First remove the printer from the group of devices.
    2. Reboot with the printer attached.l
    If the printer does not automatically reinstall, then manually add it by using the Add Printer selection.
    If you have two printers in the list delete them both and then reboot.
    Dec 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    No HP devices detected. HP Solutions Center will close now.
    It might help to uninstall the HP devices through the Device Manager, and then restart the computer. Let the computer try to detect the HP devices and install them and the drivers needed. You might want to have any software discs handy in case you have to reinstall any software that came with the printer, etc.
    Feb 12, 2009 | HP Computers & Internet
    when it hangs,right click the task bar and open task manager and from the process tab stop the file wrapper.
    In device manager click on view and select show hidden devices.
    U will see and imaging device keep updating it and
    Oct 22, 2008 | Office Equipment & Supplies
    OK that is something really big well dont have to worry there is another small thing that you can try ...
    1. If you have the S/w CD then insert it in the computer open my computer >> Right click on the CD ROM drive and select the option EXPLORE >> there will be an icon that will say Util double left click on that >> You will get a folder that says CCC double left click on it >> you will get a list of different icons over there double left click on UNINSTALL_L2 >> a black window(cmd page) will open up and if u have the USB cable plugged in take it out and after that hit "ENTER" from your keyboard it will uninstall the drivers of the printer that is not getting compatible to the operating system in your computer after it uninstalls click on FINISH>>
    computer will restart itself...... after that you need to clear the TEMP folder in your computer
    ...........if XP click on start>>click on RUN>> type %temp% and hit enter delete everythig that is there after selecting any one of them and then pressing Ctrl+A on your keyboard delete everything and then try and install the S/W....
    ..........if vista type %temp% and hit enter delete everythig that is there after selecting any one of them and then pressing Ctrl+A on your keyboard delete everything and then try and install the S/W ....
    Aug 20, 2008 | HP DeskJet F380 All-In-One Printer
    HP 7410 off line with Vista & HPM8000 computer
    Once right click on the printer icon and make it online and then clear the print que and then download and install the patch from the below webpage.
    http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-54112-1&lc=en&cc=us&dlc=en&product=391194&os=2093&lang=en
    After installing the patch restart the computer and check for the result.
    Jun 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Unistall the software you have for it now. Go to HP.com and look for Vista drivers for your printer.
    May 21, 2008 | HP Photosmart 2710 All-In-One InkJet...
    HP OJ 7410 Allin1 not printing
    try removing the printer, and re adding it. Sometimes when printer drivers go kaput, they don't drop cleanly. Also, check your power arrangement, as printer drivers are notoriously suspect to power glitches, just like modems.
    Got backup?
    Feb 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    HP oj 7410 allinone
    Download latest drivers from HP site. The disk may be bad.
    Apr 02, 2007 | HP OfficeJet 7410 All-In-One InkJet...
    HP OfficeJet 7410 All-In-One InkJet Printer Logo
    321 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
