Question about EliteGroup P4VMM2 V8.1 Motherboard
Motherboard upgrade I have p4vmm2 v8.1 and 128 ddr pc266 memory. will it be compatible if i use 512 ddr pc400 memory? And what video card is compatible to my motherboard
  • leunell Feb 16, 2008
    Yes i will not mix pc266 to pc400. But is it ok if i replace 512 pc400 to my 128 pc266.
    And what compatible video card/memory is compatible to my motherboard. thanks..
    what is compatible video card for my p4vmm2 v8.1.
    Brigadier General:
  • 3,614 Answers
Dont mix your pc400 to the pc266.
Posted on Feb 16, 2008
  • micromaster
    micromaster Feb 16, 2008
    its ok.
  • micromaster
    take an 128 ATI radeon.
I have inserted a 1 GB mamory modual and the system is not reconizing the additional memory. Are there jumpers or switches that need to be reset?
No jumpers or switches need to set. If your going to upgrade/change your memory, just make sure that the memory your're going to insert are compatible with your motherboard. Check the system bus of your memory slots if what are the maximum system bus can support of that motherboard. Like example; DDR PC266 to PC400 or PC400 to PC800, make sure that you are not exced the maximum requirements of the memory for your motherboard it is because they cannot recognize your memory.
Jun 03, 2010 | AOpen s661FXm-7US (918EM10S6G) Motherboard
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card? -jayvee_yao@yahoo.com
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Getting POST Error "Beep" message (3 Long); on a Gateway 500SE Desk Top with an Intel (Nimitz 4000792) P4 1.8Ghz CPU . Can't run machine to ascertain BIOS; thus to determine that manufacture's unique POST...
Dear Frind i think your second ram 512MB Have PC400 Buss Speed, I think also *********** board doesn't support PC400 buss Ram, Please try Ram with PC266 Or PC333 Buss speed. Best Regards sumon
Mar 20, 2009 | Computers & Internet
Memory card upgrade
no! PC266, you can change them to CP3200.
if the clock on the motherboard is adjustable, you may able to get away with PC400. in general, it is not a good idea to do that.
Nov 03, 2008 | EliteGroup P4VMM2 Motherboard
Asrock K7VM2 Motherboard Memory Upgrade
Some MOBO support different type of memory modules like ddr 400, 333,533 and other, if your computer is working fine with that PC400 it only means that your MOBO is compatible with it. Since you're planning to upgrade the memory just get another PC400 because the memory should be the same to work fine.
Jun 06, 2008 | Asrock K7VM2 Motherboard
P4vmm2 motherboard
you can add up to 2 gb RAM using either 2 x 184 Pin DIMMs or 2 x 168 Pin SDRAM DIMMs. However that MB does support pc400. The supported RAM speeds are 100, 133, 200, and 266 MHz
You can buy a pair of Kingston 256 MB DDR SDRAM PC2100 (266 MHz) from the kingston website for under $50
part no: KVR266X64C25/256
Kingston is a well known and respected manufacturer of memory.
Dec 15, 2007 | EliteGroup P4VMM2 Motherboard
Memory chips
You can use PC2100, see below for example http://www.amazon.com/Memory-Upgrade-PC266-PC2100-AA32C12864-PC266/dp/B00009OYBA
Sep 21, 2007 | Intel Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
RAM Support
if it works there is no problem, as the system would not boot up, but your memory will run at the slower of the two speeds, which will be PC266 and not PC333, as the faster speed ram is backward compatable because it always runs on the slowest speed.
Jul 30, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 V8.1 Motherboard Logo
216 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
