Question about Samsung Digimax S800 Digital Camera
Stuck the lens of my camera is stucked it neither swithes on or off again, and the lens is wide open.
  • Anonymous Feb 16, 2008
    samsung digimax s800 my lens ist stock
  • carmel0 Apr 05, 2008
    my camera doesnt turn on when i press da power button nd it jus blinks and beeps then turns back off
Could it be that there is something stuck in the lens barrel? Possibly grit of some sort? I would suggest pushing the lens in gently until the front shutter closes, then try to power on again, if this works and the barrel extends try to inspect for dirt in the barrel and get it out.
Posted on Mar 02, 2008
When I am at 10mm I can not take a picture. I have to move the lens to 12 mm, why is that?
What are the other settings? It could be that you are in "auto" and the camera is not getting an autofocus lock. Try having the camera in one of the manual settings.
Apr 20, 2015 | Nikon 10-24mm F3.5-4.5 Ed Af-s Nikkor Wide...
Stuck lens
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
Dec 26, 2013 | FUJIFILM Instax 210 Film Camera
Aperture lever stuck to wide open
On a film camera, the internel electronics determine the shutter speed and aperture. The camera computer figures out a higher shutter speed against the aperture speed. You have a lever on your lens that, when mounted on the camera, will keep the aperture open until you fire. That allows viewing in the brightest light. Then that aperture arm is allowed to close to what the exposure setting the camera determines when you click the shutter. You should be able to take off the lens and easily move the aperture arm and have it snap closed. If it takes a few seconds to close.. then the lens has oil on the aperture blades or the grease inside the lens is bad. These days, unless is it a very expensive lens it's replacement time. Canon lenses will fit any Canon (except Fd) film or digital camera.
Jul 27, 2017 | Canon T70 35mm SLR Camera
Nikon Nikkor 18-55mm, The lens feels stripped. How do I fix that
The Nikon Lens 18-55 wide angel inner lens loosens locks lens no picture
Aug 19, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
AF is not working
I would start to diagnosis the problem as follows: When the lens functions properly and is on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the smallest f-stop (largest number such as f22), sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. Also, the electrical connection between the camera body and the lens is via the five little ball like metal contacts (4 together and one wider spaced) found on the black ring on which the aperture ring is located. If either these contacts or the contacts on the camera body are dirty, the automatic functions may fail. DO NOT use any liquid cleaner. Gently rub the contacts with a rubber pencil eraser, being very careful to hold the camera body or lens in a position that will allow any debris to fall downward away from the body or lens. Do not overdo it. If this does not get you on the right track, let me know what you find and we will proceed from there.
P.S.: Have you made sure you have fresh batteries in the camera?
Nov 06, 2008 | Cameras
WIDE ANGLE LENS
Nikon 10.5mm F2.8G AF DX IF-ED FISHEYE-NIKKOR
Oct 30, 2008 | Nikon D40X Digital SLR Camera Digital...
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Arrrggghhhh!
The lens mechanism is shot. This will usually mean a replacement camera Check out the customer support -but I reckon new camera is going to happen any time soon
Apr 11, 2007 | HP Photosmart R507 Digital Camera
Samsung Digimax S800 Digital Camera Logo
149 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
