Question about Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KV32hs510 - Won't come on flashing light - 6 or 7 times
Hi, had a bad storm last week. Something seemed to happen to the TV. Wouldn't turn on. Light would flash 6 or 7 times. Tried unplugging and waiting. This did not work. However, waited 24 hours, plugged in and it worked.
Last night I shut theTV off for some reason (instead of the cable box). This AM, having the same issue with no picture and lights blinking 6 or 7 times.
ANy way to get this to work today? I can't have the wife and kids without TV while I go away on a business trip.
  • 149 Answers
Hi there, you have the hardware prob., at the power supply section., test the bleeder resistor which is 100 kilo ohms or higher, do some check up and test. ty
Posted on Feb 16, 2008
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Wont turn on
Yes that is an error light. If you give me a minute I will try and get you more info on your tv.
Thanks,
lee
Jun 21, 2008 | Sony KP-53S35 53" Rear Projection...
Apparently there was a bad lightning storm last night that knocked out our power. Bad thing is, when the power came back on our cable box won't turn on and neither will our tv. The tv power button just...
please call a specialist in that for assistance.
As of now and future: Follow what everyone says: "Turn off the modem and TV during a lightning storm".
Jul 25, 2013 | Televison & Video
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
The TV will not turn on. When the switch at the lower left corner is pressed the light in the switch flashs green for about 4 seconds as the TV seems to go through a start up procedure. Then the light...
The red flashing light is the service code. My guess is the power supply is bad now, but it could be something else. If the TV is under warranty, take it in and get if fixed. If it is not, then you may try to check the power supply first. Count the flashes of the red light and check online for the issues when this model flashes, 4 times or 6 times... or 9 times, etc.
Oct 10, 2010 | Panasonic TH-46PZ800U Plasma TV
KV32HS510 Blinking standy light will not turn on blinks 7 times
This happens when high voltage reaches 33k,it shuts down for safty. Unplug it from the wall outlet,then remove the back from tv,then check the power supply And horizontal circuits.for faults,with an ohm meter,check all solder joints for cold or bad solder connections,resolder most, check fuse,if no reading on the meter with one probe on one end and the other probe on the other useing the ohm scale,replace the fuse. Always replace it with the same amps,its writen on end of fuse......hope this helps...........
Feb 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony WEGA Fails to Turn On Stand-by Timer Flashes 7 Times
IC/high power transister(s) and/or other componentshas gone bad gone bad - usually from a power surge. These will have to be replaced. A technician should check these out for you.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SPN4235 TV -- red light blinks but picture doesnt come on.
being that it fell , this is already a bad sign that the screen is dammaged and it will need to be tested and looked at to see what other dammage has happen to it
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Power light flashes 3 times
more than likely the sony has a bad flyback
It is available from
www.electronix.com
Thanks Guy
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-32HS510 32" TV Logo
439 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
