Question about Fuji FinePix 3800 Digital Camera
So picture HI, my camera turns on but it seems that lens does not capture any view. although it tries to coz i see lines ...its been working fine a few days ago. i changed batteries..its red sensor light does not lit...any suggestion?
  • Fuji help May 12, 2008
    I'm having the same problem with the viewfinder. The camera comes on, but the fiewfinder will not open up. I can get it to come on if I turn the camera into the Sun when I turn it on. It will usually keep working, even turning it off on on, but if I leave it off for very long it will go back to not working.
I have the same problem with my 3800. Turning into the sun will make it come on, put after you use it for a long time it will not come on at all until you let it set for awhile. This sounds like a design defect which Fuji should address!!!!
Posted on Jun 03, 2008
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
Hi, I seem to have a problem with my Finepix Z1 digital camera. When I take a shot it seems to work ok, and the initial review image seems fine as well. But when I go back and review the image on the...
The clue is with the video.
The video function does not use the shutter. Lines on photo's or over exposure is due to the shutter not closing completely over the lens when you take a picture.
It will require cleaning which means opening up your camera and accessing the lens unit
Oct 28, 2009 | Fuji FinePix Z1 Digital Camera
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Jun 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Thanks Johnyc but ...
actually when taking photos after you click the capture button you need to keep the camera still for atleast 5secs..
try this and see.you ll be able to note the difference
Jun 18, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Not capturing a photo
Try taking a picture with the camera upside down.  Sounds odd, but it's a possible check to see if the AF mirror is hanging up.
Oct 01, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camera powers down after lens comes out
Contact Fuji re this. if under warranty it will be replaced.
If out of warranty they may offer a discount on a replacement
Jan 20, 2007 | Fuji FinePix 2650 Digital Camera
Fuji FinePix 3800 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
