Question about Motorola Mobility RAZR V3xx Cellular Phone
Ringtones when i receive ringtones via bluetooth they duplicate several times and when i delete one of them they all get deleted
    Brigadier General:
  • 7,752 Answers
Try a master reset then try again if that does not work then reflash the firmware on the phone.
Posted on Aug 18, 2008
I cant connect to my bb8100 via bluetooth
first, u would have to go into the media folder of what u want to receive. for instance u want to receive a ringtone, go to media then ringtones. go under device memory and press the menu button. scroll down and u should see "receive using bluetooth". the phone that you're receiving from should already b sending the info and should connect. you can do that 4 pics, videos, ringtones, songs, etc.
Apr 22, 2011 | Cell Phones
How do you delete ringtones from your HTC inspire
You can download OI File manager and go to the /Ringtones folder and delete the ringtones, or you can manually plug the phone to your computer via USB and navigate to the /Ringtones folder and delete them there.
Mar 20, 2011 | HTC Inspire 4G Smartphone
I am using Nokia N96. How to delet images from bluetooth?
hi go on memory card and look in recieved files, there shud be there
Mar 29, 2009 | Nokia 6630 Cellular Phone
I have a Samsung Rant, received ringtones via bluetooth
I've never received ringtones via bluetooth, but I do know Samsung made it ridiculously hard to customize your ringtones on the Rant. The only way I know of to do it, other than going online on the phone and downloading ringtones there, is to use a site like Myxer to send the songs you want directly to your phone.
Mar 12, 2009 | Samsung Rant Cell Phone
Garmin 265wt. How do you delete duplicate # fm phonebook?
I can help you with the phone numbers on your Garmin Nuvi 265WT.
The phone numbers transferred to your Nuvi are only supposed to be available when your phone is paired to your cell phone. Changing the entry on your phone should allow that entry to show up changed the next time it is paired with the Nuvi. Sometimes, a bluetooth mix up causes entries to be duplicated or entries' phone numbers to get repeated.
To correct this, I recommend backing up your favorites, clearing all user data (this hard reset will remove the phonebook info from your nuvi), and then updating your Nuvi' firmware to make sure the nuvi and cell phone bluetooth process runs as smoothly as possible in the future.
Follow these three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Erase Nuvi 265WT Phone Numbers here.
Nuvi 265WT Manuals here.
Feb 10, 2009 | Garmin nuvi 265 Car GPS Receiver
RAZOR 2 RINGTONES
Use Master Reset option Its get reset your phone
you also use Master clear option , all your phone data get erased
and also ring tone
Feb 02, 2008 | Motorola Mobility RAZR V3
When a ringtone is bluetoothed to me, it shows file is corrupt
you need to do a master clear on your phone ... you would loose ur pictures and any downloaded stuff, but your wouldn't get that file corrupt error again. Somehow your software probably got a glitch.Try the master clear or the master reset in settings and hopefully as i said this would clear the problem. You can then go ahead and try to bluetooth any files your want to. Sam !
Sep 02, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Cannot delete ringtones
HI Below is the step by step method of how to delete your ringtones in your Motorola V3: Here is an easier way to delete the ringtones without much hassle. 1) Upload 1 mp3 rintone to your phone via MPT 2) Set ALL ringtones msg, alert etc, absolutely everything for all styles (obviously excl. silent & vibe) to the uploaded MP3 3) switch your phone off, then on again. This will update the .db files. 4) Using P2K, delete all the rintones, except for the MP3 that you uploaded, do not delete the .db files. Also, do not delete the .bas files as these are the base files for Motomixer. Set all reminders to OFF. do not EVER delete a ringtone that is currently in use by the phone. If you delete it while it is active, You will NOT be able to get into that particular tone setting. 5) Switch your phone off, then on again.
May 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3xx Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
