Question about Dell Latitude D600 Notebook
My computer won't start.
When I press the power button it flashes green nothing pops up on the screen and it shuts off. The battery has a full charge. The fan doesn't move eithier. Mabey somthing's wrong with how its connected to the sceen.
  • cbase Feb 18, 2008
    I think I've got the same problem with a used D600 that I bought a few years ago: whether hot or cold, when I power up, the Power button and three keyboard status lights go on for a few seconds before shutting off. I replaced the battery but no success. One time in frustration I gave it a couple of slaps (it responds best when held on knee with left hand and spanked lightly on the right front corner!) while in the power up cycle and the darn thing started! I have been doing this now for a couple of years (though I only use the laptop occassionally) and though it always starts, I worry about it getting tired of the abuse and quiting altogether!
    Any ideas on an inexpensive fix?
    Thanks
Re-seating the memory card did the trick. Thanks D600 hater
Posted on Mar 10, 2008
Have had this problem several times - apparently these D600's are junk! Not to mention being SLOWER THAN CHRISTMAS when they do boot up! Every time I've had this problem, I just removed and re-seated the memory and hard drive and that usually gets 'em going again.
Posted on Mar 06, 2008
    Problem Solver:
  • 24 Answers
If the processor, ram and motherboard are working, there will be a display on the screen, check the processor, ram and motherboard through troubleshoot.
first: get working processor and ram then remove the ones in your system and then install the new ones, the display is on the screen, troubleshoot the removed processor and ram to find the bad one.
uzowuanya
E-MAIL:uzowuanya@yahoo.ca
Posted on Feb 16, 2008
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Sharp Mebius won't boot
I suggest that you remove the battery and use the charger only in turning on your computer. If it turns on just fine without the battery then you would need to replace the battery. If it doesn't then it's either the motherboard or the charger which has a problem.
David
Jun 10, 2013 | Sharp Mebius Computers & Internet
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
HTC Vivid won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | HTC Vivid
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Oct 30, 2008 | IBM ThinkPad T22 2647 Notebook
Not powering on
The manual indicates that the green light flashing once indicates that the camera is powering down.
http://www.manualnguide.com/dl/6597/ (see page 218 lamp indications)
The first thing you can try is to turn off the camera, remove the battery, remove the memory card. Hold for one minute , pop the battery in(but not the memory card) turn on the camera by pressing the power on buttn and holding it for 15 seconds. This will not only reset the camera but also force the motor to retrace/extend the lens if it is a lens related issue that is causing the camera to shut down.
Let me know if you need more help
Jun 04, 2017 | Casio Exilim EXZ75 Digital Camera
Dell Latitude D600 Notebook Logo
140 people viewed this question
Alun Cox
