My samsung40"lcd crack inside which i can see when it turn it on.its only on leftside of the tv.i have seen the tv for 2days.after that i can seee only the colors in the screen but i can hear the sound.is it fixable?
Unless someone is giving away a good lcd panel that is compatible with this model or selling it/auctioning it off for a reasonable price it will cost you 80% of the cost of a new television at the least to repair this. In a lot of cases the panel itself can cost thousands of dollars (I've seen them run as much as $10,000). The labor will add to the cost. The only entities I've seen repair broken panels are the network news stations because the cost is coming from the television station and not out of anyone's pocket.
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
This sounds like the panel itself is cracked. If this is the case, the set wil not completely power up as youi have seen. The panel can not be repaired as such, it must be replaced. I can rpovide you with the part number and cost if you can post the model number. Be aware however, that the cost of the panel may come close to the cost of a replacement set.
The mainboard is going bad. If you were to disconnect the cable from power board that leads to the mainboard you'll get the same result, power cycling. Replace it before it causes damage to the LCD controller board.
Sorry to say it sounds like the LCD panel is damaged.The LCD panel can cost as much as the TV and if that set was made in china you have a big problem trying to get parts. The bottom line is a very costly repair.
