Question about Sony DAV-S400 System
The system does not recognise that a disc has been inserted. Message says insert disc
I inserted a bonafide DVD and the system displays a message "Insert Disc". I I open and reclosed the system and the same message was re displayed. Can you help?
  • nilofar Feb 16, 2008
    message for biggT. new to Fixya clicked accept when meant reply. The system is a Sony DAV S400. The message "insert disc" appears after disc inserted not when system is switched on. Do you still think limit trays are sticking?
    Brigadier General:
  • 3,614 Answers
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Posted on Feb 16, 2008
  • micromaster
    micromaster Feb 16, 2008
    first in first out (FIFO)
  • 42 Answers
Do other discs work in your CD drive? If your CD drive has failed, that could be your problem
Copy-protected discs ship essentially damaged and are not compliant with CD/DVD standards, so can fail to read in strictly standards-compliant DVD drives.
Please check other disc are working like cd on your DVD if problem persist try to clen firt with god quality lens cleaner otherwise replace/repair it if its under warranty
Regards
Balisonu79
  • 640 Answers
Nilofar,it sounds like your tray limit switches arent working properly/sticking.Do you get this message before you open the tray?Give me the make and model number.
  • anthony james
    anthony james Feb 19, 2008
    Sorry so late for the post.If your not seeing the 'insert disc' message until you open the tray i agree with the other techs posts about the lens not picking up the media.Cheapest way is to spray some compressed air into the unit where the tray opens.If this doesnt work you could try a disc cleaner,where a cd actually cleans the lens.
  • Sony Master
  • 19,396 Answers
Did you try different disks? You may need to clean the lens, read this solution: http://www.fixya.com/support/t132806-insert_disc_message
hope it helps
After inserting a DVD to play a bought film or recorded disc a message comes up in the display saying No Disc
It may be dust built up and you have to get a DVD insert that's made especially for cleaning the inside of the player
Feb 09, 2012 | Sony Televison & Video
My dvd writer is unable to recognise the disc.The message no disc inserted comes after inserting the disc.It is just 15 days old
the DVD burner/plaeyr has to have compay=tibkle media , perhaps you purchased incorrect CDs or DVDs (mdeia) to burn with .. make sure the speed is compatibke with the CD or DVD media
contact the sales people at the store where you boiught the DVD player/burner and ask them to give you correct media to work with
Oct 31, 2010 | Sony Computers & Internet
Always gives the message bad disc
either the disc motor is not running up the disc speed fast enough,or the laser is burnt out.run it with the cover off and look at the disc speed.it should be about 500rpm
Jan 10, 2010 | Cyberhome CH-DVD 300 DVD Player
DVD player not reading disk
Clean the laserunit,if fault still exist then replace the laserunit
Aug 27, 2009 | Televison & Video
Cyberhome dvd 1600
unplug the unit and wait 5 minutes and plug it back in. See if that helps
Oct 21, 2008 | Cyberhome DVR 1600 DVD Recorder
ERROR MESSAGE.....
had the same LD FVU (Load FVU or firmware disc) message and fixed it this way: download firmware from http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/DVD.ASP and make firmware disc and insert. After it loads and updates, you need to activate your remote again. When the message SET 1 appears, on the remote press ENTER and 1 together for 10 seconds. Done.
Jun 24, 2008 | Panasonic DMRES15 DVD Recorder
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Sony DAV-S400 System Logo
210 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
