Question about D-Link AirPlus DI-524 Wireless Router
Wired one alright with this problem it been happening for ages umm where to begin i have an adsl modem conected to my DI 524 and im running 2 comps atm and have a mates comp over at the moment and when he connects he can connect to the net and shows up in the Dynamic DHCP Clients List i also tryed to pinging from the router to his comp and it sed it failed also i had created a work group to see if it would try and work he added him self he cant view the network group but i can This is also the same with I tunes he can see my stuff but i cant see his
  • Technosis Feb 19, 2008
    trust me mate i have done all of that ...CCNA lol but this it can get an ip but when i ping ed it it failed and that was from the router .... and the router gave the ip add ... and it still failed when i did it staticly.... could it be the router not the nic?
  • BtoB May 11, 2010
    I cannot connect to the internet with the main computer, only through the wireless router.
    Help!
  • 28 Answers
If you are not able to connect through your main comp using wireless router...then first of all check the ipaddress of computer by..
start>run>type cmd>then type ipconfig in command prompt screen.check whether you get the ip address as 192.168...........and default gateway as 192.168........
if anything else reinstall nic card on your comp
Posted on Feb 17, 2008
Hello. I've setup a LAN of 2 computers, a router and a ADSL modem at home, but when I plug both computers to the DLink 524 router, all the lights become less bright and I can't connect to the router, even...
reset set the modem first. then connect the one system to adsl modem. type 192.168.1.1 in browser. enter user name&password.go to interface setup tab-internet--select bridge mode--save and reboot. now remove that take router connect to system type 192.168.1.1 in browser. enter user name&password.go to interface setup or advance setup in that wan tab or internet tab select dynamic ip and lan page give different network address eg-10.0.0.1 for router 10.0.0.2-...254,255.0.0.0,10.0.0.1 save and reboot it will work or just call 08041478653 , 9740575949
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
Connecting to internet
you need to configure wireless on router panel using the browser.
Apr 16, 2008 | D-Link AirPlus DI-524 Wireless Router
I just conected my DI-524 with a new cable modem
The first question is whether your change of service provider really has any connection with your new lack of range. If your new cable modem contains a wireless router, it's possible it is interfering with your old router. You only need one, so in that case you should remove your DLink and configure your wireless cable router to your satisfaction. Otherwise, you may have coincidentally picked up a new source of interference; you may want to change the channel on your DLink router to see if that improves your range. The third possibility is that your DLink radio is going sour with age -- it happens -- and may simply need replacement.
Nov 25, 2009 | D-Link AirPlus DI-524 Wireless Router
I Have a D-link DI-524 wireless router and verizon Broadband modem w/USB conection the G router only has ethernet connections .How can I make this Combo work?
If your Broadband modem is only with w/USB connection you have to change modem/router, you won't connect it with usb to di-524.
Jul 05, 2009 | D-Link AirPlus DI-524 Wireless Router
I dont know how to install my D-link 524 router.i need wireless
http://www.it.hiof.no/datakom/lab/di514_QIG_103.pdf
go for this web site you go the your anwers
May 23, 2009 | D-Link DI 514 Wireless Router (DI-514)
My D 502T Adsl+2 will connect but when I try to
First of all, what IP address does the 502 give you when you plug into it alone? Do an IPCONFIG from DOS and note the numbers.
Now, what is the default IP of the 524. Is it the same as the 502?
If it is, change your 524's IP to something else, like 192.168.1.1.
If it isn't, please post back what your IP configuration is and what the link is, DSL,Cable Modem, PPPoE, or DHCP either fixed or variable.
Carl
Apr 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Why is my modem not recognised by vista ???
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
No internet Connection
this is something simple
2 things you will have to do
the router when a problem like this happens again
unplug router for 1 minute this is packet build up and then plug back in i found this out by service provider that its a build up of packets it relieves packets
now the other thing since you went threw all the little areas of trying to reset modem go in remove your network connection
delete it and build a new network connection threw the network setup wizard then your done restart comp everything should be back to normal and you wont have to ever reset network settings again
just unplug the router let sit for minute and plug back in
Jun 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Connection Problem
insatll your drver cd of router if u have connted with a usb cable
then after configar your router
the router defot ip is 192.168.1.1
type in your web page address bar
the user name is admin & pass: admin
just login & configer
& enjoy
Mar 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
61 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
