Question about Canon FAX-L350 Plain Paper Laser
Toner cartridge i have a fax canon L350 and need to know what it means when it says check printer cartridge and/or close cover
  • seanlogan Jul 11, 2008
    Error message received "check printer " Changed toner cartridge, powered fax down and powered it back up again but still receiving same error message. Any further ideas.
    Regards
    Sean
    Problem Solver:
Could be that the cartridge isnt seated correctly so the cover cant close
Posted on Jun 08, 2008
Check cover/cart appears. tried changing toner cartridge but message still there. Toner in correctly. is there anything else to check/do?
the message you are getting will show up for both toner and cover. There is a switch that the cover triggers when closed located onder the main unit cover. The tab on the cover goes into a slot located kinda left of center. That switch is infamous for getting stuck or knocked out of place so the tab does not see it. The cartridge is probably good.
Sep 19, 2011 | Canon LaserClass 2050 Plain Paper Fax
When the fax machine says "close the cover/cart" how do we clear that error message when we have checked over the fax machine, closed everything, and checked for jams.
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
May 05, 2011 | Canon LASER CLASS 2050P
Canon Fax-L350 display check printer Alarm red "could
Open the main cover. Look into the body of the machine. The covers top left corner has a projection that when the lid is closed this projection passes through a hole in the main body and hits a micro switch to say the cover is closed. the switch has stuck. Poke a thin screwdriver (power off of course) and watch the switch pop back into its right position. All will be well. A well known fault of this model.
May 03, 2011 | Canon FAX-L350 Plain Paper Laser
Check cover/cart error message
fax toner catridge door is not properly closed. when you close that there is a micro switch that is not going to activate. Please be sure it is closed properly
Nov 25, 2010 | Canon FAX-L350 Plain Paper Laser
Where is the Printer Cover on the Canon Fax 8500? The fax is asking to Check the Printer Cover.
The printer cover is the cover that you open to remove the cartridge. Open it and check that the cartridge is inserted correctly. Remove and reinsert cartridge then close the cover. Check all around the m/c to make sure all doors are closed.
Sep 24, 2009 | Canon FAXPHONE L80 Laser
Rotating toner cartridges to change
Every time you open and closes the door cover the toners rotate,open and close it untill she can see the black cartridge.
Apr 08, 2009 | Canon Office Equipment & Supplies
Error message on Canon Fax Machine 2050P check cover/cart
there are a couple of things did you buy genuine or reman cartridges and check if they are seated properly.
some remans dont work properly so you have to be sure and always get a money back guarantee from the seller
Feb 26, 2008 | Canon FAX-L350 Plain Paper Laser
Check cover/cart
May 31, 2007 | Canon FAX-L350 Plain Paper Laser
Error message saying " check cover/cart"
ok it can be a bunch of things,
1) check the cover that you open to change the cartridge is secure, press down on the top part near the latch that releases it and see if the door switch activated, if you hear the main motor activate then your problem is the locking latch.
2) Change cartridge and /or clean the 2 metal square contacts under the drum, move the drum cover and you can see the 2nd one, use methylated sririts or equivalent and a cloth. Your cartridge may be faulty/old or has leaked toner on the contacts.
If neither of these work you will have to have a visit from a technician as a circuit board may be at fault.
Apr 13, 2007 | Canon FAX-L350 Plain Paper Laser
Canon FAX-L350 Plain Paper Laser Logo
103 people viewed this question
old marine
old marine
