Question about Dymo LabelWriter 400 Turbo Thermal Printer
DYMO DUO LABELWRITER
My Dymo Duo started making a strange noise whilst trying to print the large address label, on opening up the top of the machine I found a label stuck to the roller and am unable to remove it. After only having this machine for 5 months I am frustrated as to how to remove this stuck label and in the meantime am unable to use the machine!
  • Anonymous Mar 28, 2014
    slow to open
    Problem Solver:
  • 14 Answers
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Posted on Mar 24, 2008
I have dymo 450 printer who can i change languge
https://www.manualslib.com/manual/414419/Dymo-LabelwriterAnd-174-450-Duo-Label-Printer.html?page=94
Dymo LabelWriter 450 Duo Label Printer User Manual Changing The Language...
Quoting from the manual at the web link shown:
Changing the Language (Windows Only) You can change the display language for the DYMO Label software so that you can work
in a language that is most familiar to you. Changing the language only affects the text and messages in the software. Features available in the software are determined by the operating
system locale.
To change the display language
1. Choose Preferences from the Edit menu.
2. Select the General tab.
3. Under Language, select the language you want.
4. Click OK.
The language changes immediately without restarting DYMO Label software.
Apr 08, 2018 | Dymo Office Equipment & Supplies
Beep dymo labelwriter 450 duo
It sounds faulty, so:
Call dymo tech support to confirm it's faulty (or get a solution), and if they confirm it's faulty return it to the company that supplied it to you for a replacement.
Contact:
http://sites.dymo.com/Support/Pages/ContactForm.aspx
Feb 03, 2013 | Dymo LabelWriter Thermal Printer
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
I need driver for Dymo LabelWriter Duo model 93105 I've lost disk
I've searched for Dymo labelwriter drivers before (for personal needs) and found them here:
Driver Update Software for XP Vista 7 8. have a nice day
Nov 06, 2012 | Office Equipment & Supplies
The Dymo tape editor screen will not let me enter text
  1. Ensure software and drivers are compatible with your OS.
  2. Re-install the drivers and software again.
Nov 15, 2009 | Esselte Dymo LabelWriter DUO for creating...
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
869 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
