Before you even start, your machines "Network Support" firmware needs to be up to date to be able to connect to a Windows 8.1 PC.
Secondly your machine has to be networked. No USB scanning supported on Ricoh Devices. Create a shared folder on your C: drive called "scans". Share so "everyone" can access the folder. On the MP2852 select scanner mode and tap the block with "Prg Dest" on the screen. Select Folder and Browse for your PC. Enter your PC Username and Password when asked. Find your shared "scans" folder, select it and then tap OK on the screen. Next enter your name and save. You should be good to go. Keep in mind anti-virus and firewalls can block it. Also ensure your PC is part of a "Home Group" otherwise you will not find your PC when you browse from the MP2852. If your PC is not in a "Home Group" then you can just create a "Home Group" under your "Network and Sharing Center" and while you are there ensure that "Password Protected Sharing" is switched off under your "Advanced Sharing Settings" also found in your "Network and Sharing Center".
scan and send works in two ways. It can scan to email, then you have to put smtp server on the email settings and create destination in the adress book. The other way is to scan and send to the file. Create a folder at the destination pc, share it in the network with acces rights for everyone, then create destinatinon entry in the address book. Change it to file, host name would be the ip or host name of the machine you are trying to send to. Folder path is the name of the folder you just created. Login and password would be the l/p for the pc you have created the folder at. and thats it. Should work straight away :)
Yes, the copier needs your password in order to be able to access the PC where the folder is stored. If you update your password in the copier's settings, you should be able to scan to folder fine again.
questions
1st are you able to print to the copier by wireless ?
2nd was ever able to scan to folder on your laptop by wireless ?
If the answer to both is yes try and plug your laptop into a network jack with a network cable and see if you can scan then. If you still can't it is possible the path to your folder has changed or your permission (password) has changed to your folder or the folder is not there anymore.
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Do you have the send feature or just scan? If just scan you need to install scan gear to the computer you want to scan to and configure scanner, than can pull scan fro canon to any viewer installed on your computer. If you have the send feature, make a folder on the c drive of the computer , share the folder with all permissions. Touch send on screen, reg. new address, touch file, arrow down to smb file, browser button to see your network, highlight your network, touch down highlight your computer name, enter user name and password as shown, log in to your computer from canon and highlight the shared folder and hit ok. you should now be able to send to that shared folder
you will need to have the folder shared on the desktop. you will need user name and password. go to user tools. system settings. administrator. address book. create new user. in new user program, go to folder. enter computer name. browse network. you then enter user name and password for pc. should be done
the copier needs to login into each station... like a user logs in... but it needs admin rights... so whatever account is logging in must have admin rights number one... number 2 the folder must be shared with everyone and they bust have admin rights to the shared folder... you can change that after stuff starts working but for testing thats best... third make sure that you use the ip address... the login username and the login password of the pc you are scanning to... you use the ip address because dns can destroy connection if its not configured right meaning pc name may not be detected... to test ... just goto press scan... then attempt to edit the address book entry for the pc and scroll down to the smb entry and then test... you can test it straight from the copier changing settings and testing until you get a connection... this is after you have made all changes on the pc... now once you get a connection... you are good... any more questions or if you feel this is a bit jumbled... email me and we will set up a chat session and I will walk you through it...
scanning from any device is simple you need three things
user name bill
password piguine
path \\server\scans\shared folder
the scanner needs rights to write to a folder on the network.. good luck
The IP Address of the printer is required, and the HTTP option must
be enabled on the printer. If you do not know the IP Address, or
whether HTTP is enabled, print a Configuration Report. See the Related Items
below for additional information. If you do not have this information
or the printer is not configured correctly, contact your System
Administrator for assistance.
A user account for the scanner to login to the scan server must be
created (account needs full control access rights). The user needs to
be a local user on the workstation and not a domain user.
NOTE: SMB uses local rights and not domain rights. Record the username and password for future use.
A directory to be used as a repository for the scanned files must be created. The directory must then be shared.
The Hostname of the workstation must be known.
CentreWare 5.5x must be installed on a Microsoft Windows server or workstation on the network.
From the workstation or server where CentreWare is installed:
Click on [Start], point to [Programs], select [Xerox CentreWare],
and then select [Add Network Scanner]. The Add Network Scanner Wizard
window will be displayed.
Click on the [Enable a new Xerox System Scanner for network
scanning and associate it with a scan server] radio button, and then
click [Next].
Select [Specific IP Address] from the Find Devices pull-down menu and continue with step 4, or select [Specific TCP/IP Hostname] and skip to step 5.
If Specific IP Address is selected, an IP Address field will be
displayed. Enter the IP Address of the printer in the field, click
[Next], and then skip to step 7.
If Specific TCP/IP Hostname is selected, a Hostname field will be
displayed. Enter the printer’s TCP/IP hostname in the field, and then
click [Next].
NOTE: Select Specific TCP/IP Hostname if the Printer is using DHCP to resolve the IP Address and has a Hostname assigned.
If the printer has been configured for Scan to File, a window will
be displayed with a 'This device has already been configured for
network scanning. Continuing will overwrite its current configuration.
Do you want to continue?' message. Click on [Yes].
The Enter Password window will be displayed. Enter your system
password in the field provided, and then click [OK]. The Server Type
(Filing Protocol) window will be displayed.
NOTE:
The initial system password at machine install is 1111. If the
administrator encounters a problem with changing the password, or
forgets the password, a service call must be placed.
From the Server Type (Filing Protocol) pull-down menu, select [Windows (SMB)].
Click on the [Browse] button located below the Location
(\\Server\ShareName\Path) field. The Choose Location – Windows (SMB)
Browse to the server and then to the Scan folder where the
CentreWare scanning folders will be installed, and click [OK]. The
Location field will be displayed with the scan server name and the path
to the shared scan folder.
Click [Next]. The Xerox System Login Name window will be displayed.
Enter the scan user name and password (this is the user account the
printer will use to login to the server share) in the fields provided,
and then click [Next]. The Distribution Server window will be displayed.
Do not make any changes. Click [Next].
Click on [Manage User Templates]. The Manage User Templates window will be displayed.
Click on [Modify Template List] to begin selecting template users
for this scan server installation. The Modify Template List window will
be displayed.
Make a selection from the list of Users and Groups, and then click
on [Add] to create a scan folder and template for the selected user or
all members of a selected group. If necessary, repeat this step to add
additional users or groups.
When you have finished, click [OK] twice. The Finish window will be displayed.
Click on [Finish] to upload the scan settings to the printer. The
Add Network Scanner Wizard window will close when the settings have
been uploaded.
