Question about Logitech X-230 Computer Speakers
Volume level I've had these speakers for a year or two. I've noticed that they're putting out a much lower volume than they were when i first got them. If i have the volume at about 9 o clock, with full volume on my computer, most things are almost inaudible. Any suggestions?
  • baudelaire Feb 24, 2008
    The problem seems to be the volume control (cheap shit ones like this get dust in them and that's it. I'm trying to find out how to get into the speaker itself so I can bypass it, as it's not needed. It would be SO easy if they had a couple of screws to open it, cut cut the switch out of the loop and tie the wires together. My concern though is destroying the box trying to get it apart.
  • Anonymous Mar 29, 2008
    sound locked
  • 417 Answers
Make sure that the sound level on your windows is set correctly.
Thanks J
Posted on Feb 16, 2008
The volume of my model's volume only goes up to 40...is there a way to increase the volume?
Sometimes you can connect a lower ohm speakers. However you must NOT go lower than the amp can take. For example if the amp has 8ohm as the lowest for it you can go to 8ohm speakers, if it has 16ohm speakers connected, but must connect 6ohm speakers. If the amp allows 6ohm than you can connect 6ohm speakers. Changing from higher level speakers to lower level ones will make the volume louder. But you must not connect ones lower than the rating of the amp.
The only other way is if there is something wrong with the amp and that it won't go higher due to a fault.
Oct 27, 2017 | The Audio Players & Recorders
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
Woofer sound distorted
What audio source you put into your Amp? you can lower the source volume also the amp volume to confirm, where the problem come.
Source input is also important whether you using low level or hi level input.
Nov 18, 2012 | Acoustic Research P315 HO Speaker
Volume issues on JVC FS-Y1
As far as the speakers are concerned 6 ohm speakers should not have damaged the unit, unless some of the connections wires short circuited. But I think that would have blown the channel not reduced the volume. If you had connected 4 ohm speakers to a 6 ohm amp that would have been a different matter entirely.
The only thing that I can think off that would do this is some kind of circuit that detects the ohm level and adjust it when you put different ohm speakers on. 6 ohm speakers would off course be quieter than 4 ohm ones.
So if you have 6 ohm speakers still on then it will detect that and reduce the volume for them. But at the end of the day it connecting 4 ohm speakers back up should cause it to reset. It might take some time for this to happen!
If the device has a factory reset try that with the old speakers on it. That would reset it back to 4 ohms.
Otherwise get in touch with JVC to see if the unit does indeed have an adjustment ohm setting built in and see what they have to say.
Apr 07, 2017 | JVC FS-Y1 Shelf System
One of my Q 75's is just not performing properly,all the drivers make sound,just not enough of it,I've swapped both speakers from right to left so it's not wiring or the reciever.No buzzing or...
Try reversing the POLARITY of the wires on the speaker that is playing at a low volume (swap wires connected to the + and - terminals of the speakers). This would put the speaker back in phase if it were reverse connected, and provide the expected volume level again.
May 23, 2011 | KEF Audio Q75 Speaker
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
Cannot get sound is there a switch to put sound on
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 12, 2010 | Logitech Quickcam Chat Webcam
Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Jan 23, 2008 | Onkyo TX-SR500 Receiver
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Logitech X-230 Computer Speakers Logo
35 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
